correct spring?
Old Jun 9, 2003 | 10:49 PM
homers3's Avatar
homers3
Default correct spring?
Did all 81's come with a fiberglass leaf spring? Mine has Gymchana and has a 9 leaf steel spring. Is this correct?
Old Jun 10, 2003 | 01:43 AM
Steve Grodin's Avatar
Steve Grodin
Default Re: correct spring? (homers3)
Fiberglass - reinforced monoleaf rear spring for those cars equipped with automatic transmission and standard suspension. :chevy
Old Jun 10, 2003 | 12:28 PM
Gator81's Avatar
Gator81
My understanding of it is this: The gymkhana option (RPO FE7) on the '81 should have meant a switch from the standard 9-leaf steel spring on a 4-speed car to a stiffer 7-leaf steel spring. On an '81 with automatic transmission, it would have meant a switch from the new composite monospring to the same 7-leaf steel spring.
If my understanding is correct, then the answer to your question is "No".
To correct spring?
