Diff. Oil, what type?
Old Jun 10, 2003 | 11:24 AM
Jeffski's Avatar
Jeffski
Default Diff. Oil, what type?
I know it has been covered in some previous threads, but what type of oil do you use combined with what firction additive for my rear diff. The car is a 77 with 3:08 gears / Automatic.
Jeff :yesnod: :yesnod:
Old Jun 10, 2003 | 12:17 PM
Gator81's Avatar
Gator81
Default Re: Diff. Oil, what type? (Jeffski)
Hi, Jeff.
I'm using Mobil 1 synthetic gear lube, 75w-90, GL-5, with one 4-oz bottle of the GM posi-traction additive. Can't recall exactly how much lube it takes to fill the diff. Seems like it was two of the 1-liter bottles. :seeya
Old Jun 10, 2003 | 12:38 PM
1LE's Avatar
1LE
I recently changed mine, and stayed with all GM lube and addative.
Old Jun 10, 2003 | 01:47 PM
LT-1 Larry's Avatar
LT-1 Larry
Getting ready to put mine back in this week. The rear-end guru who rebuilt it says to go with synthetic (like the GL-5) and GM addative.
Old Jun 10, 2003 | 02:20 PM
Gator81's Avatar
Gator81
Default Re: Diff. Oil, what type? (1LE)
If I were doing it again any time soon, I'd be tempted to go with the GM standard instead of the synthetic. With about 105K miles on it, there was a slight seep at the seals with the old lube, but now there is noticably more leakage past the side yokes with the synthetic. Not a big deal yet, but still not a good thing. I like the features of the synthetic, but increased seepage seems to be in issue.
Old Jun 10, 2003 | 04:06 PM
PatG's Avatar
PatG
I just use the GM stuff, seems to work fine for me.
Old Jun 10, 2003 | 05:23 PM
mvftw's Avatar
mvftw
Default Re: Diff. Oil, what type? (PatG)
I just changed mine... GM additive & Castrol 80w-90 dino
Old Jun 10, 2003 | 06:37 PM
mapman's Avatar
mapman
I just used the GM Limited Slip Axle Additive #1052358 (4 oz), and the GM Axle Lubricant SAE 80W-90 #1052271 (0.68 L) as specified in the shop manual.
Old Jun 11, 2003 | 03:55 AM
RC81's Avatar
RC81
Default Re: Diff. Oil, what type? (mapman)
Just did mine with Mobil One and one tube of additive. Took 2 qts.
To Diff. Oil, what type?
