differential noise
Old Jun 11, 2003 | 10:01 AM
yogi78's Avatar
yogi78
Default differential noise
After winter storage the rear end makes a little noise at slow speeds @20-25 mph when the differential is "floating". Otherwise it is quiet and does not chatter in turns. The fluid was changed last fall with the GM posi additive and all was fine until this spring. I've done the figure 8 thing, just wonder if anybody has any other ideas other than a rebuild of the diff. Thanks :chevy
Old Jun 11, 2003 | 01:06 PM
pws69's Avatar
pws69
Default Re: differential noise (yogi78)
I just changed my 4 spd and rear end fluid yesterday - Mobil 1 in both with GM Posi additive in rear. I am AMAZED at how much quieter the entire gear train is now - and I had no complaints before! Every time I have changed over to Mobil 1 in any vehicle, something dramatic happens - usually noise and ease of shifting.
Old Jun 11, 2003 | 01:14 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I had some noises in mine and it turned out to be a cracked posi case and damaged spider gears :eek: :eek: :eek:
Old Jun 11, 2003 | 03:41 PM
Alwyn678's Avatar
Alwyn678
Default Re: differential noise (pws69)
Dont forget the Oil Seepage out of the seals :lol:
Old Jun 11, 2003 | 03:56 PM
pws69's Avatar
pws69
Default Re: differential noise (Alwyn678)
Not a problem - I use good seals. :lol::smash:
To differential noise
