71 Windshield wiper door adjustment problems.
Old Jun 11, 2003 | 03:01 PM
nada's Avatar
nada
Default 71 Windshield wiper door adjustment problems.
I recently compared the tightness of my wiper doors against some other early C3s. Apparently, I have got some components that have been worn out or incorrectly installed. It is obvious that some one has had the doors off at one time. There are rubber shims and/or washers (spacers) under the grill retaining screws. The screws seem to be stripped and will not tighten. The door that is against the windshield has some play in it. It moves about 1/4 of an inch when rocked bad forth (lifed from the window side up and down). I am assuming based on looking at other cars, that there isn't supposed to be any noticeable "play" with the door if it is installed properly. What is likely to be the problem that is causing this looseness and the installation of these shims/spacers? The grill portion is about 1/4 inch high on the passenger's side. I am familiar with the expensive bolts and bushings that are available. Could the problems lie there?
