Turn signal help
Old Jun 12, 2003 | 02:40 AM
JohnG76's Avatar
JohnG76
Default Turn signal help
ok here's my dilema now, i hit the turn signal left / right, nothing happens or flashes... but i hit the brakes and both turn arrows inside light up green... which turn singals outside are suppose to flash front/ back, so i knwo which light bulbs to check for current, etc
thanks
Old Jun 12, 2003 | 11:16 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
Default Re: Turn signal help (JohnG76)
Ground problem...........I would guess a wire has worn somewhere, and is shorting to a legit ground.
Old Jun 12, 2003 | 03:03 PM
JohnG76's Avatar
JohnG76
Default Re: Turn signal help (gliot1)
but when i hit the brakes are the turn signal indicators suppose to light up?
Old Jun 12, 2003 | 03:48 PM
ImBatman's Avatar
ImBatman
John,
Welcome to my world. :cry I am troubleshooting the electrical system in mine right now. I agree that it sounds like a ground issue. You also may want to check the flasher and see if it is still good. I turn my lights on and both green arrows light up. :mad
Old Jun 12, 2003 | 11:00 PM
Jim 77's Avatar
Jim 77
Default Re: Turn signal help (BlackRat)
It's also worth a shot to check all of your bulbs. Make sure the two filament bulbs still have two filaments!
To Turn signal help
