Does anybody know how to test the wiper motor when it is out of the car. Wipers worked Ok , but froze suddenly. All voltages at terminals checked ok, except for intermitent.
Check if your center console is getting a good ground... A bad ground connection at the center console if a frequent problem...
The console between the seats? Coincidently, my wipers quit too on the way into Dallas last week. There is 12v at the wiper motor but nothing happens when switched.
I"M sorry not the center console the damn INSTRUMENT cluster...gauges...in the center of the dashboard....in front of the console....
that has to be grounded, and if the metal bezal is broken at the weak point near the bottom front edge of the wiper switch insert...with the air duct vents in it also....that is the problem...switch not getting a good ground...run a wire...or buy another gauge cluster frame....
BTW, I have one for sale...new looking...100 bux....
