Can you check flashers?
Old Jun 12, 2003 | 03:50 PM
ImBatman's Avatar
ImBatman
Default Can you check flashers?
That would be the ones used for the turn signals and emergency flashers. Not the ones running around in trench coats :eek: :D
Old Jun 12, 2003 | 03:56 PM
79VetteMike's Avatar
79VetteMike
Default Re: Can you check flashers? (BlackRat)
Figure out whic terminals are the poles for the relay. Apply 12 volts and you should be able to hear it clicking. Call an autoparts store and ask if they have a relay checker.
Old Jun 12, 2003 | 04:01 PM
ImBatman's Avatar
ImBatman
Default Re: Can you check flashers? (79VetteMike)
What about with a volt\ohm meter?
Wade
Old Jun 12, 2003 | 04:37 PM
Sleper's Avatar
Sleper
I beleive there are two in the car. One on your fuse pannel and one behing the glove box I think. The one on the pannel is cheap. Not sure of the other one. Hope this helps.
Old Jun 13, 2003 | 10:04 AM
ImBatman's Avatar
ImBatman
ttt
To Can you check flashers?
