69 Wiper Electrical Troubleshooting
Old Jun 13, 2003 | 02:08 AM
69_BigBlock's Avatar
69_BigBlock
St. Jude Donor '03 & '05
Default 69 Wiper Electrical Troubleshooting
Finally got the vacuum issues resolved and the wiper door opens when the wiper switch is moved to Lo or High. Unfortunately, the wipers do not come on. I have checked the fuse and confirmed the service switch is turned to the left (counter clockwise). The limit switch plunger seems to be engaging the switch.
What troubleshooting can I do to determine where the problem is? I'm embarrassed to admit that I've never had to troubleshoot an electrical problem so I don't know where to start. :confused: :confused:
Thanks for the help!
Ron
Old Jun 13, 2003 | 09:38 AM
pws69's Avatar
pws69
Default Re: 69 Wiper Electrical Troubleshooting (Ron_98vert)
Ron
Ron, things to check that will cause "no power":
1. Make SURE (with a meter) the llimit switch is closing.
2. Make sure the ground wire is attached to the wiper motor. There should be a spade lug at around 12:00 looking at the motor with a black wire attached.
Paul
[Modified by pws69, 9:40 AM 6/13/2003]
Old Jun 13, 2003 | 10:27 AM
tabbruzz's Avatar
tabbruzz
Aside from checking for a GOOD ground connection to the motor, I usually remove the wiper motor and with a couple small jumpers(wires) I connect them directly to the battery. If the motor turns on then it's most likely a good motor. Alot of times it's simply a faulty gound connection.
Tony
Old Jun 13, 2003 | 12:15 PM
69_BigBlock
Thanks for the suggestions. I'll check it out this weekend.
Does anyone have a wiring diagram they could email me (rbrinton01@yahoo.com)?
Ron
Old Jun 13, 2003 | 12:40 PM
dreamn2's Avatar
dreamn2
Ron, I just went through the same problem. Make sure there is a Black ground wire coming from the blower motor on the passenger side to the wiper motor housing. Also make sure the plug is not on the wiper switch backwards. It will fit either way and if its wrong it will let the cycle option work but not the low/high.
Old Jun 13, 2003 | 09:14 PM
A C's Avatar
A C
Cruise-In II Veteran
Ron
You might want to get a laminated diagram from Lectric Limited...somthing like this.
They are very big, like 2' x 3', so they are easy to read, and the lamination helps so you don't wreck it when your hands are all greasy. I have a 69 too, and with 34 year old wires, I am sure the diagram will come in handy. One of my better investments, I think. :yesnod:
AC
Old Jun 13, 2003 | 09:59 PM
RMVette's Avatar
RMVette
:iagree: with all the above. And don't be like me and forget to have the override switch on. They certainly won't work then! :banghead:
Old Jun 16, 2003 | 02:30 PM
coldwarrior2000's Avatar
coldwarrior2000
Default Re: 69 Wiper Electrical Troubleshooting (RMVette)
Question: will the wipers work if you do not have the override switch hooked up?
Old Jun 16, 2003 | 02:40 PM
coldwarrior2000
Default Re: 69 Wiper Electrical Troubleshooting (coldwarrior2000)
Also, where exactly is the wiper relay located? (Not the wiper solenoid on the back of the tach)
To 69 Wiper Electrical Troubleshooting
