My future engine is starting to move forward :)
Old Jun 13, 2003 | 05:29 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default My future engine is starting to move forward :)
Well like the title says, I'm finally starting to see some progress
The new Dart Little M block with 4.125" bore is being prepped and measured to order the custom JE pistons I need for the Bryant 3.625" billet crank & 6" H beam rods I have. I'm going for 11.0:1 compression. The pistons should take about 4 weeks to get.
I just ordered my mech roller cam from CompCams. The numbers are 248/254 dur @ .050, .614/.621 lift with 1.6 rockers 112` lobe separation with cam being installed @ 108`.
My heads are Brodix Track 1's that have been ported & polished.
The intake is an Accel single plane highrise intake made by Lingenfelter Performance for EFI along with my 1200cfm billet throttle body I got from them. I have 42lb injectors and plan on controlling everything with a Holley Commander950 ecu. Not sure what size feed line I should go with yet ?
So what do you think, and comments/ suggestions on my custom sbc :)
[Modified by SmokedTires, 5:30 PM 6/13/2003]
Old Jun 13, 2003 | 05:33 PM
JohnS_77's Avatar
JohnS_77
Default Re: My future engine is starting to move forward :) (SmokedTires)
Can I get a ride when it is done? :seeya
Old Jun 13, 2003 | 05:34 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
That's it.... :smash: :smash: :smash: What did you run out of money. Sounds ratical to me. :yesnod:
Old Jun 13, 2003 | 05:35 PM
SmokedTires
St. Jude Donor '05
Default Re: My future engine is starting to move forward :) (JohnS_77)
can I go for a ride?
Of course you can silly :yesnod:
[Modified by SmokedTires, 5:36 PM 6/13/2003]
Old Jun 13, 2003 | 05:38 PM
SmokedTires
St. Jude Donor '05
Default Re: My future engine is starting to move forward :) (Budman78)
Money, what money :crazy: . My vette is a great funnel for all my money ;) .
Old Jun 13, 2003 | 05:44 PM
Scott78's Avatar
Scott78
Sounds like an awesome combination. It should spin up pretty fast, I'm guessing around 500HP and 450 ft-lb in torque. Interesting choice of stroke length, what made you go for 3.625 vs 3.75 or longer, the rpm response?
Old Jun 13, 2003 | 05:48 PM
SmokedTires
St. Jude Donor '05
Default Re: My future engine is starting to move forward :) (Scott78)
I went with the 3.625 because I got a pretty good deal on it from Ebay. I'm hoping the quicker revs should be an added bonus. ;)
Old Jun 13, 2003 | 05:53 PM
Fevre's Avatar
Fevre
You may not need that large of inj's and it makes it harder to control idle quality with inj's that are too large. I would shoot that question out on the C-4 forum to get some feed back. I would think 36lbs might be large enough unless you plan NOS or supercharging. Again I am not sure but thought I would bring it up.
Sounds like it should be a load of fun! :thumbs:
Old Jun 13, 2003 | 05:56 PM
Alwyn678's Avatar
Alwyn678
Default Re: My future engine is starting to move forward :) (Fevre)
Man that car is certainly gonna be a beast......I can hardly wait to hear how she Performs :eek: :cheers: :cool:
Old Jun 13, 2003 | 05:59 PM
SmokedTires
St. Jude Donor '05
Fevre I originally had 36lb injectors but got nervous that I might have to pump the fuel pressure up too high to feed my horsepower goal of being close to 600hp at the flywheel. I've heard that if the fuel pressure gets to high it can cause the injector to stick open. This is a learn as I go, so I may end up going bvack to the 36lb after everything is together.
Old Jun 13, 2003 | 09:43 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I don't know anything about EFI or Dart blocks but that sounds like a hi-tech engine Mike. No expense spared! @108 should give a lumpy idle? No? Why the change? :D
Old Jun 13, 2003 | 10:17 PM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In IV Veteran
St. Jude Donor '03
Sounds great Mike, I'm just sittin here grinnin' :D
Dave
Old Jun 13, 2003 | 10:20 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: My future engine is starting to move forward :) (Rolling Thunder)
Mike when you get that thing done im gone to have to come up and check it out for sure. :thumbs:
Old Jun 14, 2003 | 08:32 AM
SmokedTires
St. Jude Donor '05
Default Re: My future engine is starting to move forward :) (patsnitrovette)
Thanks guys, I'm getting pretty excited myself :D .
Old Jun 14, 2003 | 09:19 AM
QuickVet's Avatar
QuickVet
wow. that is going to be some engine :eek:
Old Jun 14, 2003 | 01:49 PM
Monty's Avatar
Monty
Default Re: My future engine is starting to move forward :) (QuickVet)
Very nice engine combination. You'll never have to make excuses for that parts combination. Those injectors are fine, you'll have no problem getting it to idle just fine, especially with that cam. I ran 50# on my 650hp NA SBC 427, and 83# on my TT SBC 427. I tuned each to idle smoothly at 800-850 rpm. Don't be afraid to run 30+ degrees of total timing at idle.
Old Jun 14, 2003 | 09:18 PM
SmokedTires
St. Jude Donor '05
After hearing what your ole` man is running at the local track, it's time to up the ante :reddevil .
Thanks Monty, I'm sure I'll have swome questions as I get closer to the tuning stage ;) .
To My future engine is starting to move forward :)
