Flex fan sizing
Old Jun 14, 2003 | 12:33 PM
dudeskie's Avatar
dudeskie
Default Flex fan sizing
I need to know if a 17 inch flex fan will fit in my 79. Thanks guys
Old Jun 14, 2003 | 01:14 PM
dudeskie's Avatar
dudeskie
Default Re: Flex fan sizing (dudeskie)
No takers on this one either?
Old Jun 14, 2003 | 01:31 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
measure your current fan, or better yet the opening of your radiator shroud. The best fit is a fan that is 1/2 the way into the shroud, and 1/2 the way out (when viewed from the side) and has about 1/2 to 3/4 inch clearance all the way around.
Old Jun 14, 2003 | 03:23 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
i would say don't go with a flex fan.
you can get a clutch fan and clutch at Autozone for about 45 bucks.
I hate the way a flex fan sounds at high rpm and dubious about its cooling efficiency.
Old Jun 14, 2003 | 03:38 PM
69vette66's Avatar
69vette66
Default Re: Flex fan sizing (turtlevette)
I had a 18 inch flex worked great but loud, so I went with a 17 inch, no problems in the last month with it. The 18 inch was about a 1/8 to 1/4 inch away from shroud, causing it to a turbine like sound which I didn't care for.
Good Luck :cheers: Larry
Old Jun 14, 2003 | 08:03 PM
guppie's Avatar
guppie
St. Jude Donor '08
I have an 18 1/4" on my 78 L48
To Flex fan sizing
