Firestone-1 C3-0
Old Jun 15, 2003 | 06:13 PM
LS1 HP's Avatar
LS1 HP
Default Firestone-1 C3-0
My bro was driving home the '81, and obviously, had a blowout. The entire tread came off of the Firestone, leaving only the metal part of the tire - tire still fully aired. I guess that's not really called a blowout...damage is decent :banghead:
Old Jun 15, 2003 | 06:33 PM
99inDenver's Avatar
99inDenver
Default Re: Firestone-1 C3-0 (CandaceBell)
:eek:
Hope nobody was hurt.
Old Jun 15, 2003 | 06:58 PM
CRAIGVETTE's Avatar
CRAIGVETTE
Veteran: Coast Guard
Senior Member
Cruise-In V Veteran
Ouch! Hope nobody was hurt and that you get everything fixed soon. Will Firestone pay for any of the damages?
Old Jun 15, 2003 | 07:05 PM
Drop_Top_Dave's Avatar
Drop_Top_Dave
Kid Rock Fan
Cruise-In IV Veteran
That really is a bummer! I'm sincerely sorry that happened.
On a side note, that's the most unusual looking C5 I've ever seen! ;)
Old Jun 15, 2003 | 07:22 PM
BUGGSY1970's Avatar
BUGGSY1970
Default Re: Firestone-1 C3-0 (Drop_Top_Dave)
This sounds to me a lot like the Ford Explorer tire situation. I would call Firestone and give them hell. A tire should not seperate at the treads unless it is badly worn, underinflated , or poorly made.
Old Jun 15, 2003 | 07:25 PM
Larry B.'s Avatar
Larry B.
What kind of Firestones?
Old Jun 15, 2003 | 07:31 PM
Corey_68's Avatar
Corey_68
Default Re: Firestone-1 C3-0 (bluevetteman)
:eek: Becareful out there!
My friend with a '99 white Hardtop C5 put hers in the canal the other night. She was exiting an off ramp when her tire blew and caused her to swerve and put the Vette in the ditch. They of course totalled it.:cry
Becareful with that red rocket. :thumbs:
Old Jun 16, 2003 | 09:25 AM
Alwyn678's Avatar
Alwyn678
Damn that really sux :eek:
Old Jun 16, 2003 | 09:50 AM
Mystery Machine's Avatar
Mystery Machine
Yikes! Firestone=Danger! :eek:
Old Jun 16, 2003 | 10:21 AM
bbeck's Avatar
bbeck
OUCH!! That really hurts, hope Firestone does something. Luckily your brother wasn't hurt at all. My uncle told me a story about a C3 back in the 70's when they had the same problem with their tires, and both passengers were killed. Very dangerous situation. Good luck getting touch with someone that can help you at firestone.
Old Jun 16, 2003 | 11:03 AM
Steve Straus's Avatar
Steve Straus
Firestone..The best tire that one can recall.
Only tires I use are BFGoodrich/Michelin.
Old Jun 16, 2003 | 11:23 AM
MIKER's Avatar
MIKER
Were they Firestone Firehawks, Firehawk Indy 500's, or something else?
How old were the tires? What air pressure do you run in them? How fast were you traveling?
I'm running a set of the Firestone Firehawk Indy 500's http://temp.corvetteforum.net/c3/miker//02061929fix.jpg so I would REALLY like to know the details.
I once had a tire throw the tread while staying inflated. It caved in the quarter panel really bad. That was on a '74 Firebird Formula.
Old Jun 16, 2003 | 11:26 AM
Corz's Avatar
Corz
Default Re: Firestone-1 C3-0 (Steve Straus)
I currently run Goodyear on my 69, but am upgrading to BFG's soon
Old Jun 16, 2003 | 11:27 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Just.... Damn.
Old Jun 16, 2003 | 01:39 PM
SnoDrgn's Avatar
SnoDrgn
From: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In VI Veteran
Damn :crazy: :nonod: That's gonna be one expensive blowout
Old Jun 16, 2003 | 01:47 PM
e3pres's Avatar
e3pres
St. Jude Donor '08-'09
:eek:
Old Jun 16, 2003 | 05:55 PM
mrvette's Avatar
mrvette
Over the decades, I have had some real garbage out of Goodyear too, so you all really down on F-en irestone don't surprise me, but I will never buy a Goodyear either....
GENE
To Firestone-1 C3-0
Old Jun 16, 2003 | 06:43 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
firestone gets this nasty wrap because fraud, oops, i mean ford slammed them durning the whole exploder thing. i don't believe there is anything wrong with firestones on average. if you believe in bridgestone tires, you might as well believe in firestones too. same tire. what is the pressure? i'm sure it gets pretty hot down there in beaumont so pressure and temperature are a huge factor. :skep:
here in vegas, i can pass a half dozen cars a day in the summer sitting on the side of the road with shreaded tires. i'm sure they're not all firestones. hell, i had a tread separation in my truck last year with some cheezy 'general' tires. especially in hot conditions, too little pressure can easily result in overtemping a tire.
as for the firestones, i'll have to experience it before i believe it. i ran a set of firehawk sv50's for years. finally burned them up in a donut contest at a speedventures event. burnt them all the way down to the steel belts and they still held air. (that's them in my sig pic at that same event) i'd rather buy firestones at full price than discounted goodyears.:rolleyes:
BTW, i'm glad nobody was hurt. i feel for the damage to the vette. :sad:
Old Jun 16, 2003 | 06:46 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Firestone-1 C3-0 (clutchdust)
that looks bad :cry
Old Jun 16, 2003 | 06:51 PM
Larry B.'s Avatar
Larry B.
Default Re: Firestone-1 C3-0 (mrvette)
[QUOTE]Over the decades, I have had some real garbage out of Goodyear too, so you all really down on F-en irestone don't surprise me, but I will never buy a Goodyear either....
I Have had Very bad luck with Goodyears. Terrible... Cone shaped, pull to one side. Hard to balance. One was 1/4" out of round. I had one fly apart one our van. I replaced a completely WORN out set of BF goodrich T/A's with a new set of Goodyear GT's on one Corvette a few years ago. Instantly worse. I kew I had made a mistake within two blocks. Ihad to have them shave to make the car drivable. Goodyears? NEVER again.
