Differential Yoke retainer C-ring
Old Jun 16, 2003 | 11:22 AM
rponfick's Avatar
rponfick
Default Differential Yoke retainer C-ring
I am planning to replace the yoke needle bearings (since I seem to have an extra pair) and side seals in my '69 differential (with 4.11 gears). Any mechanics out there have any hints about getting the c-clip retainers removed and then installed. I know clip ring pliers are required, but any hints would be appreciated. You don't seem to have a lot of room to work with in getting them off and on.
Thanks.
Old Jun 16, 2003 | 01:01 PM
ram82fire's Avatar
ram82fire
Default Re: Differential Yoke retainer C-ring (rponfick)
Get a quality set of right angle snap ring pliers ,,,,,,,,,,, the kind with out removalble tips !
gman :thumbs:
Old Jun 16, 2003 | 05:11 PM
Mack's Avatar
Mack
Default Re: Differential Yoke retainer C-ring (ram82fire)
gman :thumbs:
:withstupid: Yep... I figured I wasn't going to use them but a couple of times, so I bought a cheap pair. So, after I broke 'em, I bought some good ones.
Old Jun 16, 2003 | 05:30 PM
GTR1999's Avatar
GTR1999
Ralph, the 90* snap ring pliers are the way to go. I have a pair that are fixed tips and work better then any of the replaceble tip pliers I've used. I used to get them at the local bearing house but haven't seen them in years. I've seen the industrial snap ring pliers Sears has and they look pretty good. Those are replacement tip plier too.
Gary
To Differential Yoke retainer C-ring
