Front End Ride Height Adjustment?
Old Jun 17, 2003 | 01:20 PM
TotallySmoked's Avatar
TotallySmoked
Default Front End Ride Height Adjustment?
I just put in a new engine with aluminum heads and intake. Needless to say, the entire front end of the car, rides extremely high now due to the weight reduction. Anyone have this problem and if so, what did you do to remedy the situation?
Thanks in advance.
Smoked.
Old Jun 17, 2003 | 02:36 PM
goofygrin's Avatar
goofygrin
Default Re: Front End Ride Height Adjustment? (TotallySmoked)
You could get different front springs... That should lower it about an inch right?
Old Jun 17, 2003 | 02:44 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Re: Front End Ride Height Adjustment? (goofygrin)
Autozone or Oreilly's BB springs for $59.00. They a Moog's. Install and wait a day. If you don't like the height, then cut off a high coil and reinstall. Cut until you are happy or dragging the front air dam.
:lol:
Old Jun 17, 2003 | 04:01 PM
TotallySmoked
Default Re: Front End Ride Height Adjustment? (Budman78)
Yes, I already know of cutting the coil springs. I was hoping there was something less involved than that. I guess I will just have to bite the bullet.
Old Jun 17, 2003 | 08:59 PM
Duke94's Avatar
Duke94
Did you go from a big block to a small block? I went to aluminum heads on my 78' L-82 and didn't notice any difference in ride height. Did you have the front suspension apart? If so, maybe the spring isn't seated in the lower control arm pocket. Had this problem on my 71' and it sat high. Had to disassembly the control arm and reset the spring to get it back.
Old Jun 18, 2003 | 10:04 AM
TotallySmoked
Default Re: Front End Ride Height Adjustment? (Duke94)
I did have the entire front suspension off and redone. I am pretty sure I twisted the springs back into their seat in the bottom A-Arm. I will check, thanks. I had a SB originally and have a SB now. It also has an aluminum intake.
To Front End Ride Height Adjustment?
