headlight hinge pin replacement???
Old Jun 18, 2003 | 01:35 PM
71roadster's Avatar
71roadster
Default headlight hinge pin replacement???
Has anyone done this? I replaced the bushings but when I put it back together I noticed one of the pins was still rattling around quite a bit allowing the whole assembly to shake. I had thought the pins were part of the casting but apparently they are pressed into the casting and over time the hole in the casting opened up and allows the pin the move a little, just enough to **** me off anyways - the assembly still shakes around when the car is idling! Really makes the car look like a clunker when sitting at a light on cruise night!
I was thinking of pulling the pin, drilling through the casting, and using a .5 inch bolt bolted to the casting. But I am wondering what other folks have done. Replacing the whole casting seems like a very expensive solution to a simple problem.
Chris
Old Jun 18, 2003 | 01:45 PM
72GACRZR's Avatar
72GACRZR
Default Re: headlight hinge pin replacement??? (71roadster)
Are you sure that's what allows the movement and not the stop adjustment?
Just a heads up. :seeya
Old Jun 18, 2003 | 03:23 PM
GTR1999's Avatar
GTR1999
Those look like they're shrunk in,trying to press them out would probably break the support. I just rebuilt my headlights and the hinge pins were worn, I used liquid steel to blend them in. Are you sure the hinge bearings aren't worn out? they're just plastic bushings so they may be the problem?
Gary
Old Jun 18, 2003 | 09:16 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I haven't tried this, but if the casting is worn you might be able to find a machinist to make a new set of pins with a little bigger end for the casting. Then drill out the casting and secure the new hinge pin with a roll pin (After cross-drilling). The pin is not supposed to be loose in the casting, in fact I believe they were cast in place. Other way would be to spring $$$ for new assemblies :eek:
To headlight hinge pin replacement???
