shift kit for automatic
Old Jun 18, 2003 | 10:12 PM
jetech's Avatar
jetech
Default shift kit for automatic
What does the shift kit for the automatic do? what are the advantages and how hard is it to install one. :confused: :confused:
Old Jun 18, 2003 | 10:21 PM
Jvette73's Avatar
Jvette73
Default Re: shift kit for automatic (jetech)
It makes the upshifts firmer and quicker. Its actually good for the trans as it clamps the clutches togeather faster which helps reduce the wear on the linings. Its not to dificult to install. It involves removing the trans pan. Dropping the valve body and installing a different seperator plate and tossing a check ball or two. kinda messy job with draining the fluid and all. If you get a kit that give you options like towing or street/strip. Always go for the more agressive street/strip setting. Thats my 2c
Old Jun 18, 2003 | 10:49 PM
NHvette's Avatar
NHvette
Default Re: shift kit for automatic (Jvette73)
:iagree:
Exactly. but my B+M kit came w/ 3 options: Towing, Street 'n' Strip, and Racing.
I went St/St - and I am very happy with it. Beware that some people don't
want to be able to spin the tires when shifting under heavy throttle.
The first day I drove mine, I was slowly passing an 18 wheeler. He put his
blinker on to switch into my lane. I punched it at 55MPH, downshifted to
2nd and got a nice chirp out of the tires. If that's what you're looking for - go for
it. It's pretty easy.
:seeya
[Modified by NHvette, 10:50 PM 6/18/2003]
Old Jun 19, 2003 | 07:03 AM
jerryp58's Avatar
jerryp58
There should be a bunch of archived posts on shift improver kits.
Here's a Web page I created about my B&M install... http://users.erols.com/jerryp58/corvette/bnmkit.htm
A lot of members like the TransGo kit, but it is supposed to be a little more complicated an install than B&M.
I'm still enjoying mine :yesnod:
Old Jun 19, 2003 | 09:41 AM
Alwyn678's Avatar
Alwyn678
Default Re: shift kit for automatic (jerryp58)
I have the Trans-Go Reprogramming kit and I really like it. I have it set for VERY AGGRESSIVE....But I like to nail second and third :reddevil
[Modified by Alwyn678, 9:42 AM 6/19/2003]
Old Jun 19, 2003 | 12:18 PM
Glutamine83's Avatar
Glutamine83
Default Re: shift kit for automatic (Alwyn678)
will a shift kit help in your E/T's?
Old Jun 19, 2003 | 04:11 PM
Matt Gruber's Avatar
Matt Gruber
Default Re: shift kit for automatic (Glutamine83)
if you set it to chrip on a shift, the trans may last a long time, but the rest of the car won't.
it will help ET's however :yesnod:
Old Jun 19, 2003 | 04:17 PM
Alwyn678's Avatar
Alwyn678
Default Re: shift kit for automatic (Matt Gruber)
Uhhhh Why>>?????????????? :confused:
Old Jun 19, 2003 | 05:05 PM
Matt Gruber
it will shorten the life of all driveline parts.
i'm not convinced the trans will last longer. the clutches will for sure, but bang shifts do not promote long life of other parts.
Lastly, sooner or later you will hit a slick spot and combined with a bang shift the car may spin off the road, and this can shorten its life :yesnod: mine did this as per the previous owner, but i took it apart and selected the RV/tow setting. It is still very firm and sometimes will spin the tires on a 5700 shift. But i have not got sideways since.
Old Jun 19, 2003 | 05:09 PM
Alwyn678's Avatar
Alwyn678
[QUOTE]it will shorten the life of all driveline parts.
QUOTE]
Never had these problems before on any of my cars but interesting theory.
:cheers:
[Modified by Alwyn678, 5:09 PM 6/19/2003]
To shift kit for automatic
