So.. I'm sure some of you want to know what I've got planned for the BEAST, so here goes
355 cid (4bolt main)
9.5:1 compression
Vortec Heads
XE268 cam
Performer RPM air gap
Demon 650 cfm carb
Dynomax ceramicoat headers (1 5/8th)
DYNO'D in Chevy Hi Po Magazine
426ft lbs@ 4000 rpm
390hp @ 6000 rpm
Is this the trade deal you mentioned a while back (engine work for painting your acquaintance's car), or are you getting this engine from a different builder? Just curious... :cool:
The guy i was going to trade with is having second thoughts.. he priced out a 375hp engine and it came out to 1600 dollars. he thought that was a little too high for a paint job so he is un sure. I'm going with my former boss who builds race engines.
does anyone know if the XE268 cam will need a higher stall convertor? I'd like to run the stock one if possible :smash:
need to know rear, and driving habits.
a 268xe will work but i don't know if you will be satisfied. Lots depends on how well it is tuned. my xe262 works well, but i am 50 and don't want to squeal the tires(too many cops around here)
3.08 rear with posi.. driving habits? it depends on my mood. I do like getting on it. but i dont like driving it too hard.. i definatley dont want to blow this one sky high. however i do want some power on tap :smash:
besides, I wanna whoop up on this dork with an Admiral Blue C4 :jester
i drive mine hard 30-90.
it shifts at 56 into 2nd
90 into 3rd. 3.08 rear.
i roll into the throttle flooring it at 30
a 3.08 is not going to give drag strip launches.
you will need to recalibrate the governor for 6000 shifts to take advantage of the 268xe :cool:
This guy is obviously smoking something, or he doesn't expect a very nice paint job. :yesnod:
I shift it manually.. besides, if i HAVE to drag race it, thats where the 2400 stall convertor will come into play :lol:
Corey, I think you'll be satisfied with the 268 cam. I had it min my 327 before I yanked it out. It had a very noce lope at idle, good torque and midrange, all around great cam. :yesnod:
