Shutting Headlamps Problem
Old Jun 19, 2003 | 01:59 PM
pra4sun's Avatar
pra4sun
Default Shutting Headlamps Problem
I have read some threads here about folks having problems with their headlamps opening. My problem is just the opposite. Both pop up just fine, but when I go to close them, the right headlamp closes immediately, but the left lamp takes awhile. Sometimes I give up, shut the car down and the headlamp will close after driving it awhile the next day.
Any ideas?
Old Jun 19, 2003 | 02:09 PM
72GACRZR's Avatar
72GACRZR
Default Re: Shutting Headlamps Problem (pra4sun)
Have you checked the condition of the four helper springs on each light? :seeya
Old Jun 19, 2003 | 03:12 PM
wcsinx's Avatar
wcsinx
Sounds like a leaking vacuum relay. Try swapping the relays left to right and see if the problem switches sides.
[Modified by wcsinx, 8:12 PM 6/19/2003]
Old Jun 19, 2003 | 03:15 PM
NHvette's Avatar
NHvette
Default Re: Shutting Headlamps Problem (wcsinx)
If the headlight stays up, yo ucan close it by hand. Just push in on the 'knee'
of the connecting linkage. Once it starts closing, just push down on the cover.
Could be a leaky hose, too.
:seeya
Old Jun 19, 2003 | 03:36 PM
wcsinx's Avatar
wcsinx
Default Re: Shutting Headlamps Problem (NHvette)
:seeya
:iagree:
Ayuh, could also be a hose, but if it only happens on one side and only when going down, then that narrows it down to one hose. It'd be the one going from the vacuum relay on that side to the back side of the the actuator.
Old Jun 19, 2003 | 04:48 PM
Larry B.'s Avatar
Larry B.
Don't forget about the actuator seal. One relay valve could also be bad. switch then and see if the same headlight stays up. If the other light stays up it is a bad relay. If the same light stays up, the seal in the actuator is shot.
Old Jun 20, 2003 | 10:15 AM
wcsinx's Avatar
wcsinx
Default Re: Shutting Headlamps Problem (bluevetteman)
seems like an actuator seal would cause trouble going both up and down though
To Shutting Headlamps Problem
