Vortec Heads
Old Jun 20, 2003 | 06:37 PM
CircleW-72's Avatar
CircleW-72
Default Vortec Heads
Just bought a new set of GM vortec cylinder heads anyone know what intake manifolds would work with stock hood ,I know space is limited :banghead:
Old Jun 20, 2003 | 07:34 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Default Re: Vortec Heads (CircleW-72)
most aftermarket intakes are taller than stock. When i ran an Edlebrock performer i used a thin carb. base gasket to help make up the difference.
Old Jun 20, 2003 | 08:53 PM
69stingray's Avatar
69stingray
You can find a stock Vortec manifold, maybe off of a truck or something. Edelbrock Performer for Vortec should fit with a drop base air cleaner. There are also vortec style TPI manifolds if you want to add fuel injection.
Old Jun 20, 2003 | 09:00 PM
joe73vette's Avatar
joe73vette
Default Re: Vortec Heads (69stingray)
I think the only carb manifolds for vortecs are the Performer and Performer RPM air gap. I don't know if they are different heights than the non-vortec versions. I understand that the standard Performer fits under the hood with the stock air cleaner assembly. I hope the performer vortec fits, as that is what I am planning on using on my 73. Joe
Old Jun 21, 2003 | 04:36 AM
Sting Raycin's Avatar
Sting Raycin
Any stock vortec manifold will be made for stock FI, and will not work with your carb. the performer vortec should work. You might also check GM's performance catalogue. They may have a low profile manifol for the vortec heads.
Old Jun 21, 2003 | 01:14 PM
BKbroiler's Avatar
BKbroiler
The Edelbrock Performer for Vortec heads will fit with a Qjet and stock air cleaner under the stock hood.
Old Jun 21, 2003 | 02:59 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Vortec Heads (BKbroiler)
:iagree:
Old Jun 21, 2003 | 11:16 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Holley has one now too. :D And Chevy of coarse (Performance Parts cataloge). :chevy
[Modified by cardo0, 10:17 PM 6/21/2003]
To Vortec Heads
