choke light keeps flickering while driving
Old Jun 20, 2003 | 11:42 PM
rick s's Avatar
rick s
2nd Gear
Default choke light keeps flickering while driving
im new to corvettes, just bought my first one a 80 L-82 and while driving my choke light on the dash flickers on and off and there is a buzzer that makes noise while the light flickers also , drives me crazy , any help?? and there seems to be a little left to right play in the steering wheel while driving, it does need new tires and im sure a front end alignment, but i thought you might have other suggestions? thanks for any help
Old Jun 21, 2003 | 12:08 AM
OkeeGuy's Avatar
OkeeGuy
Default Re: choke light keeps flickering while driving (rick s)
choke light? hhhmmm...
i dont have one oof those...
as far as the sloppy steering goes, i will wait and see what others here say cause most of the guys here know what my answer would be... STEEROIDS :lol:
Old Jun 21, 2003 | 12:20 AM
Stevo81's Avatar
Stevo81
On my 81, the choke lite works on more than just the choke. I couldn't pass smog with the choke lite on, so it had to be fixed. Can you run the diagnostics by the ashtray? :flag
Old Jun 21, 2003 | 12:31 AM
ROD NOCK's Avatar
ROD NOCK
I looked up your vette's year, an '80.
Most likely cause I've found on this:
Check your alternator connections (and ground). If OK, check the alt output.
Good Luck -Rod :chevy
Old Jun 21, 2003 | 02:18 AM
wombvette's Avatar
wombvette
Default Re: choke light keeps flickering while driving (ROD NOCK)
Just fixed one last week, doing the exact same thing and it was the brown wire on the Alternator. Was broken at the plug.
To choke light keeps flickering while driving
