My cooling solution for overheating in a '79 C3.
Old Jun 21, 2003 | 11:41 AM
sparkplug99's Avatar
sparkplug99
Default My cooling solution for overheating in a '79 C3.
I am new to the forum, only posting a couple of times when needing some help. The forum responded and the help offered was swift and correct; the posters solved my problems.
Now I would like to share my cooling solution that worked for me and maybe it might help someone else with the same problem.
Four years ago we bought our '79. The previous owner had cooling problems and we tried everything (new pump, fan clutch, changed radiator from 3 row to 4 row, nothing worked). I bought the car and continued to try to find the problem and in the meantime cracked two right hand exhaust manifolds.
When we decided to do a tune up on the car we discovered the advance weights were rusted tight and there was no advance. We replaced the distributor, "road set" the timing and the difference was unbelievable. More power and IT DID NOT RUN HOT!
Move forward to this year when the first hot spell hit. Suddenly the car started running well over 220 again. The faster you went the hotter the car would run. I checked the distributor and timing and things seemed correct. Car ran hot, worse gas mileage, no pickup. Then I thought to check the vacuum advance and it had a hole in it and was not working. I replaced the vacuum advance and we are back to between 190 and just below 220, gas mileage went back up and the car runs great.
This is just a thought for those of you who have tried "everything" and your shark still runs hot. I hope this will help someone. Thanks.
Old Jun 21, 2003 | 12:14 PM
Fevre's Avatar
Fevre
Default Re: My cooling solution for overheating in a '79 C3. (sparkplug99)
Sounds like you have learned a lot about your car, it will come in handy as the years go by and you are enjoy many nice cool cruises.
I like many thought if it is running hot than it most be the cooling system, well not always. The eng is a interactive system and although not rocket science it does take some knowledge to diagnos a problem such as running hot. Thanks for sharing, that is what the forum is all about.
:cheers:
Old Jun 21, 2003 | 12:46 PM
Paul L's Avatar
Paul L
Excellent tip! I lube the weights every spring after winter storage. And welcome to the Forum!
Old Jun 21, 2003 | 03:25 PM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: My cooling solution for overheating in a '79 C3. (paul79)
Paul, do you rotate the air in your tires every year too....????
Good tip BTW... :cheers:
Old Jun 21, 2003 | 04:59 PM
79MakoL82's Avatar
79MakoL82
WOW!! Great info!!!! Thanks for posting. Have to print this one for the archives for just such an occasion (myterious overheating).
And once again Paul79, just what the heck is this "winter storage" you keep talking about? :confused: :D
Old Jun 21, 2003 | 05:45 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: My cooling solution for overheating in a '79 C3. (79MakoL82)
It's the opposite of keeping it in the garage becuase it will melt in 900 degree sun
Old Jun 21, 2003 | 07:11 PM
1979toy's Avatar
1979toy
Default Re: My cooling solution for overheating in a '79 C3. (MotorHead)
Using distilled water and a MINIMUM amount of anti-freeze helped my cooling issues a bunch.
Old Jun 21, 2003 | 08:01 PM
DMONSVETTE's Avatar
DMONSVETTE
Thanks for posting that solution. :thumbs: :seeya
Old Jun 21, 2003 | 08:16 PM
isosceles's Avatar
isosceles
Thanks for sharing that with us. It is something I don't think a lot of people (including myself) would have checked. :smash:
Old Jun 22, 2003 | 10:32 AM
mrvette's Avatar
mrvette
I lube my computer DPFI/HEI every winter too.....
may retard the timing a bit in my case....
GENE
Old Jun 22, 2003 | 02:05 PM
Paul L's Avatar
Paul L
Default Re: My cooling solution for overheating in a '79 C3. (Desertdawg)
I leave the tires alone. They have 1979 St. Louis air in them ;) .
To My cooling solution for overheating in a '79 C3.
