HEADMAN HEADERS??
Old Jun 22, 2003 | 08:46 PM
silver79's Avatar
silver79
Default HEADMAN HEADERS??
JUST WONDERING WHICH HEADERS YOU GUYS USED I JUST ORDERED A SET OF HEADMAN CIRAMIC COATED HEADERS BUT I HEARD THEY WHERE NOT THAT GOOD. ANY COMMENTS WOULD BE APRICIATED.
Old Jun 22, 2003 | 08:54 PM
gdh's Avatar
gdh
Default Re: HEADMAN HEADERS?? (silver79)
I have the regular Hedman's ie. non ceramic coated, I think that the ones you ordered are fine. What most ppl comment on with the Hedman, Dynomax and even Hooker cc headers is that the quality of the coating inside is not as good as having it done by a co. that specializes in c. c. MotorHead on this forum just had his Hedman's (at least 5 yrs. old) coated locally and they look great. Hope this helps.
Old Jun 22, 2003 | 08:57 PM
silver79's Avatar
silver79
Default Re: HEADMAN HEADERS?? (gdh)
DID YOU HAVE ANY PROBLEMS WITH THE HEADERS LINKING EXHUST?
Old Jun 22, 2003 | 09:00 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
I have the Hedman ceramic coat with the A.I.R fittings. Same headers you have, just with the extra tubing.
I love them. They fit in just fine. The only thing close is the idler arm, but there is enough room.
I called Hedman about the installation. They say to use the gaskets that come with the headers and use some good bolts, like the Stage-8 locking bolts. They said to install them and torque them to 20 on all of the bolts and then 30. Drive for 1/2 hour and then park it. Let it cool overnight and then re-torque back to 30 and then install the locking collars for the bolts.
You may want to call them and ask them about the total torque again. I am pretty sure they said 30, but you will want to check on that.
They said NOT to use the metal gaskets such as the copper or aluminum ones. They said people crush them done to make it so they don't leak. After that the will not "spring back" like the paper gaskets and then you will have leaks. The only way to get rid of the leaks it to torque them down more, and then you warp the flanges, ruin the gaskets and may ruin the threads or break a bolt.
Again, call them to get the best info on installation and gaskets.
Old Jun 22, 2003 | 09:04 PM
silver79's Avatar
silver79
Default Re: HEADMAN HEADERS?? (BSeery)
HEY THANKS FOR THE INFO, THAT MAKES ME FEEL MUCH BETTER. I WAS GOING TO GET THEM WITH THE AIR PUMP FITTING BUT I WANT TO CLEAN OUT THE ENGINE COMPARTAMENT.
Old Jun 22, 2003 | 09:07 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
I didn't have a choice as I have emissions to pass down here. I tell you though, it was a massive pain in the azz getting the bolts torqued and then put locking colars on them with the A.I.R. tubing in the way. You won't have that problem, but I think that a Corvette with angle plug heads with headers that have A.I.R. pipes must be the hardest combination to ever do headers.
Old Jun 23, 2003 | 08:33 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Heck Mine has standard heads, and it's enough of a pain in the ****! And I have no idea at all, how they expect you to torque them. Thats never going to happen - ya just have to get them til they feel tight because you'll never get a torque wrench near them.
Old Jun 23, 2003 | 09:21 AM
Garson's Avatar
Garson
I have the ceramic coated Hedman's on my 74 after trying three sets of dymomax. The Hedman's fit great and no leaks......
Old Jun 23, 2003 | 09:23 AM
fauxrs's Avatar
fauxrs
Default Re: HEADMAN HEADERS?? (SanDiegoPaul)
Well not all of them anyway........
To HEADMAN HEADERS??
