GENerator light has starting coming on.
Old Jun 24, 2003 | 04:06 PM
grp's Avatar
grp
Default GENerator light has starting coming on.
Noticed the last few times I went for a spin that the GEN light has starting coming on. I'm in a 1978 L82. Is this an indication of a bad alternator? Thanks to anyone that has time to answer.
Old Jun 24, 2003 | 06:16 PM
Skeets's Avatar
Skeets
Default Re: GENerator light has starting coming on. (grp)
is it just coming on dimly? .... say, when you have electrical equipment switched on (headlamps/ wipers etc?) .... and at low revs?
Old Jun 25, 2003 | 12:34 PM
SC78PACECAR's Avatar
SC78PACECAR
8th Gear
Mine did the same thing in my 78 pace car. I replaced the alternator and no more trouble.
Old Jun 25, 2003 | 06:54 PM
Yeller81's Avatar
Yeller81
Default Re: GENerator light has starting coming on. (SC78PACECAR)
Same thing here on my 81 . Replaced the Alternator . Problem gonzo.
:steering:
Old Jun 26, 2003 | 09:38 AM
grp's Avatar
grp
Default Re: GENerator light has starting coming on. (Yeller81)
Thanks guys and sorry about the delay in my response. Our Email server was down and I just received notification that you guys had replied. Guess I know what I will be doing this weekend (alternator install).
Old Jun 26, 2003 | 09:57 AM
ROD NOCK's Avatar
ROD NOCK
First check all the connections to the alt. If OK, pull the alt and take it down to a shop/parts store that will check its output. They should be able to tell you which component is defective. Repairing/rebuilding the alt is another alternative to replacement and can save you some $$. :hurray:
Old Jun 26, 2003 | 10:43 AM
grp's Avatar
grp
Default Re: GENerator light has starting coming on. (ROD NOCK)
Good thought. I will check the belt and connections first. Thanks again.
To GENerator light has starting coming on.
