SURVEY: Engine Requirements
Definitions:
Dura-Durability. A durable motor is not only reliable, but also can handle repeated abuse. It would be able to start in any weather. It would also be equipped with a forged crank, 4 bolt caps, etc. Think marine engine.
Ecno-Economy. If you like to see how far you can drive on a single tank of gas, this would be your primary concern. Think overdrive, EFI, vac advance, etc.
Perf-Performance. If you think horsepower is king and has ultimate supreme authority over the other options, this would be your first choice.
Thanks for your participation :cheers:
It's a mass produced motor yes, and some thing that is a bad thing. My belief is that they are all built equally and won't have a goof or oops like having a main cap loose or not getting the valves shimmed right.
The motor has decent performance (350 HP and 400 Trq), it's not earth shattering but it runs with a stock smooth idle and won't overheat in the AZ temps either. Gas mileage is decent as well. I think all 3 are equal in the ZZ4 engine.
Definitions:
Anyway - interesting poll....
:thumbs:
Fuel Economy, I don't care for that at all.
If its 4 bolt and forged with EFI and overdrive you could sit in 350hp and be reliable as anything, have good fuel economy, and be powerful. Now granted 350hp to some isn't enough but for me thats plenty. :cheers:
1. Performance
2. Performance
3. Performance
Oh and did I mention performance :) . Gas mileage and reliability weren't a concern when I built the motor. Although the motor is pretty reliable.
[Modified by bence13_33, 1:40 PM 6/26/2003]
1. Performance
2. Performance
3. Performance
I added economy just to mix up the selection a little. I also wanted to see how it ended up - 2nd or 3rd. It's always cool to find on a road trip that you're pulling down 17 mpg, kind of icing on the cake after all the work involved putting a motor together..
As far as my description of durability, I used steel crank & 4-bolt as examples. Is a steel crank more durable than a cast? - Yes. Are 4-bolts more durable than 2? - Yes. I didn't say one was better or more cost effective than the other.
fauxrs-
I always thought O.D. & vac advance were to increase economy/mileage? I could be wrong.
[Modified by 71coupe, 2:52 PM 6/26/2003]
fauxrs-
OD and Vacc advance certainly contribute to fuel economy, however the point I was trying to make is a street vehicle with vacuum advance will be more tractable than the same vehicle with a locked in at max advance or even a mech advance, only which will run less efficiantly at part thottle until maximum advance is achieved. If this efficiency nets better fuel economy that is all very fine and well, but it also part of achieving better performance on the street in all the power bands you might experience.
OD as well will contribute to fuel economy, but it will also increase durability by reducing engine temps and RPM's over prolonged periods.
I purchased an OD tranny not so much for increased fuel economy , but for the ability to drive it on the freeway with my 3.70:1 rear gears without spending all my time at 4000 rpm and 200+ degrees. Now at the same speed I'm just a hair under 3000 rpm and 185 degrees. This will increase my cars durability as well as give me a perceived increase in performance.
Anyway, I guess I mistakenly took your examples as criteria...thats all.
:seeya
[Modified by fauxrs, 4:49 PM 6/27/2003]
