I didn't mark my flywheel
Old Jun 26, 2003 | 12:22 PM
rexx78's Avatar
rexx78
Default I didn't mark my flywheel
I didn't mark my flywheel position when I took it off. Is this going to be a problem when I re-install it?
:banghead:
Old Jun 26, 2003 | 12:42 PM
pws69's Avatar
pws69
Default Re: I didn't mark my flywheel (rexx78)
Only if it was balanced as an assembly previously.
If you had the flywheel turned, then no.
bence13_33's Avatar
bence13_33
No, the flywheel should only go on one way.
Old Jun 26, 2003 | 03:17 PM
Jvette73's Avatar
Jvette73
Default Re: I didn't mark my flywheel (bence13_33)
:iagree: Its drilled offset so theres only one way all the holes will line up.
To I didn't mark my flywheel
