1980 Tachometer
Old Jun 26, 2003 | 01:46 PM
azswede1960's Avatar
azswede1960
Default 1980 Tachometer
HELP - tach not working.....please tell me what to check before I tear the whole thing apart. It doesn't work at all (shows 0 rpm when running) and jumps to 15-20 when engine goes off.
Old Jun 26, 2003 | 08:42 PM
terry82's Avatar
terry82
Default Re: 1980 Tachometer (azswede1960)
first check to see if its pluged in to distributor cap ,then check if tach filter is okay , if all that checks out you will have to get behind the dash .mid america book page 3-126 has rebuild kits for $99.99
[Modified by terry82, 7:52 PM 6/26/2003]
Old Jun 27, 2003 | 12:51 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: 1980 Tachometer (terry82)
I think Ecklers has them cheaper - like $75 ish.
Old Jun 27, 2003 | 02:31 PM
Col-UK's Avatar
Col-UK
There is a cicuit board on the back of the tacho. Aparently they are prone to failure.
Old Jun 27, 2003 | 08:57 PM
azswede1960
Hi Terry - there is a connection to the distributor, and then there is a connector hanging off that (hmmmmm), is that the "filter" that should be connected there and what does the filter do?
Old Jun 27, 2003 | 10:17 PM
terry82's Avatar
terry82
theres a wire coming from the distributer to the filter [ it looks like a old condenser] then it goes to the circuit board in the back of the dash . the filter is suppose to keep the tach needle from jumping around alot sort of smooth it out.the tach will work with out it.the circuit board seems to be the thing that goes out the most . theres a replacement for that but i dont see any filter replacements.
Old Jun 28, 2003 | 01:06 AM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
There is a spare connector on the wiring harness to plug in a hand held tach. This is helpful for mechanics doing tune-ups when setting idle and timing. Also a good place to wire in a tach to verify how accurate the dash tach really isn't.
Old Jun 30, 2003 | 09:16 AM
baja216's Avatar
baja216
Default Re: 1980 Tachometer (BSeery)
Can you give me some idea of where I can find the spare connector? I'd like to verify my tachometer.
:auto:
Old Jun 30, 2003 | 02:05 PM
azswede1960
Default Re: 1980 Tachometer (baja216)
The spare connector on my 80, is pigtailed right off the connector that goes into the distributor connector.
To 1980 Tachometer
