starter won't turn over when engine is hot
Old Jun 26, 2003 | 04:08 PM
RLaFarge's Avatar
RLaFarge
St. Jude Contributor
Default starter won't turn over when engine is hot
My vette just stated this weird activity. It will start and run fine. But if I drive a while, stop and turn it off. When I turn the key, nothing at all. I can let it sit for a little while and it turns right over and starts.
Is the starter crapping out on me or is there a bigger problem looming?
Thanks in advance,
Robby
:confused:
Old Jun 26, 2003 | 04:12 PM
Alwyn678's Avatar
Alwyn678
Default Re: starter won't turn over when engine is hot (RLaFarge)
It is called Heat Soak......You need to either get a Mini starter or a Guard to protect it from heat called a Heat Shield
Old Jun 26, 2003 | 04:14 PM
RLaFarge's Avatar
RLaFarge
Default Re: starter won't turn over when engine is hot (Alwyn678)
Okay, I have heard of heat soak, but I thought it only happened to a big block. Who carries the mini staters or heatshields? :confused:
Old Jun 26, 2003 | 04:29 PM
Alwyn678's Avatar
Alwyn678
No it happens to all kinds of cars....Including my vette and 67 Firebird.....Summit or Jegs should have both probably
Old Jun 26, 2003 | 04:33 PM
RLaFarge's Avatar
RLaFarge
Thanks for the info. I found the shield and that starter at ecklers. I am going to try the heat sheild first. :steering:
Old Jun 26, 2003 | 04:47 PM
Alwyn678's Avatar
Alwyn678
Good that is usually the cheapest remedy to the problem :cheers:
Old Jun 26, 2003 | 04:58 PM
bence13_33's Avatar
bence13_33
There could be two possibilities. One could be starter heat soak, which is what I think it could be. The other is too much timing advance. Both will cause the motor to have fits whenever you try to start it when it's hot.
To starter won't turn over when engine is hot
