brake caliper problems
Old Jun 27, 2003 | 11:38 PM
jetech's Avatar
jetech
Default brake caliper problems
I decided to take a few hours and replace my rear calipers. Well neither metal brake line would break loose so I had to cut the lines but planned for that and have new lines. Then one bolt holding each caliper wouldn't break loose an then the bolt heads eventually snapped off. :mad :mad :mad It was time to walk away until tomorrow. I have the broken studs drilled just under the size of the threads so I think I can try to clean it out with a tap. if that doesn't work maybe a heli-coil will. :crazy: :banghead:
Old Jun 28, 2003 | 06:36 AM
ROD NOCK's Avatar
ROD NOCK
Default Re: brake caliper problems (jetech)
Dealing with corroded/siezed fasteners plays a large part in :smash: working on these older cars. :banghead: Having the right tools will save countless hours!
Just don't break-off a tap while trying to restore your threads! I would first apply some heat, followed by a straight flute extractor and massive penitrating oil.
Heads up for a tool link via I.M.
Good Luck -Rod :chevy
