S/C SB or N/A BB?
Old Jul 1, 2003 | 02:06 PM
BB wowbagger's Avatar
BB wowbagger
Default S/C SB or N/A BB?
How about it? I`m building a new engine from scratch and come to think about supercharging :thumbs: .A healthy Mouse with a nice Procharger and a nice cam or a mildly tweaked Rat.
The power output should be around 550 Hp and as much torque i can get.I dont not race my car at the strip,i just like to cruise around those twisties outside town and just "drive" the car.
Any ideas on this? :cheers:
Old Jul 1, 2003 | 02:15 PM
pingdashf's Avatar
pingdashf
Default Re: S/C SB or N/A BB? (BB wowbagger)
My choice would be the super chargerd SB. I don't know alot about them, or big blocks, but I would assume the BB is going to have more torque and less gas efficency. And S/C's are just so cool.
Old Jul 1, 2003 | 02:23 PM
Fevre's Avatar
Fevre
A supercharged sb 383 or 396 would be sweet, I am in process of buying parts for a supercharged EFI 383. I am hoping for about the same numbers as you ( maybe just a little more ;)) plus knock down 20+ mph on the e-way.
Old Jul 1, 2003 | 02:31 PM
BB wowbagger
Default Re: S/C SB or N/A BB? (Fevre)
What i`m looking for is driveability,much bottom end.500-550 Hp and 550Ft/lbs should not be a problem to muscle out of a s/c mouse.Mpg is not much of a issue. :cheers:
All my friends think i`m crazy going from a Rat to a Mouse.
If you compare the costs for the two,who will come out on top? :cheers:
Old Jul 1, 2003 | 02:36 PM
Robert N's Avatar
Robert N
I prefer potent small blocks. So much more statisfying to tell the owner of a BB that the car that blew his/her's away has a mouse motor in it. :D
Old Jul 1, 2003 | 02:42 PM
Fevre's Avatar
Fevre
Plus parts are cheap, well relatively cheap :D , and plentiful. if I ever build a drag only car, or buy a chevelle, I'll probably go with bb.
Old Jul 1, 2003 | 02:47 PM
BB wowbagger
..and the Mouse is lighter,lighter car=more spunk :thumbs: :cheers:
Old Jul 1, 2003 | 04:28 PM
Matt Gruber's Avatar
Matt Gruber
stay with the BB. :cool:
BB are very rare
SB's are everywhere
Old Jul 1, 2003 | 04:30 PM
gdh's Avatar
gdh
I 100% concur with the above, go s/c sb route to meet your req'ts on those twisties. I love bb but would not put one in my vette. I am very happy with my 383 it performs great and returns @ 19 mpg at cruise.
Fevre's Avatar
Fevre
Default Re: S/C SB or N/A BB? (Matt Gruber)
BB are very rare
SB's are everywhere
Must be reason for it then! Just using some rev psych on ya Matt.
Old Jul 1, 2003 | 04:41 PM
bence13_33's Avatar
bence13_33
A mild big block should be able to satisfy the 500-550 horsepower goal....and you'll have change left over! Price around for a supercharger plus whatever motor parts you want to use for the small block. Dollar for Dollar the naturally aspirated big block will be cheaper. Not to mention you already have the radiator, brackets etc... for it.
OR
Why not go with a supercharged big block :D....that's what I'm doing.
Old Jul 1, 2003 | 04:58 PM
BB wowbagger
Default Re: S/C SB or N/A BB? (bence13_33)
Well,that would be sweet,maybe build the bottom end to be able to handle it in the future :cheers:
Old Jul 1, 2003 | 05:21 PM
WA 2 FST's Avatar
WA 2 FST
As many have said, either combo can be setup to easily produce your goal of 500-550hp.
Actually a blown SB that only produces that is weak in my book. I had a SBF (331cubes) that put out 675+hp (chassis dyno'd at 615 at the wheels). Got 22mpg on the highway with a 5-speed OD trans. I used a Vortech blower, but the ATI Prochargers have come a long way and are very good. This car was not a daily driver by the time I had reached this power level, but was very, very streetable. I even had catalytic converters on it since it was a late model, smog car.
But I would definitely price it out first. A blown SB is not going to be that cheap. If its going to handle the real power potential of the Procharger, then you will want a forged bottom-end and a 4-bolt block. Run the CR ~8.75:1-9.0:1 with aluminum heads and you could run 12-14psi on pump gas all day long. Do NOT spend all this $$ to run a 5-6psi blower. That is a waste, IMHO.
Good luck.
Old Jul 1, 2003 | 05:34 PM
Jvette73's Avatar
Jvette73
Vettes are top end cars. Go with a high winding SB. In street trim and tires, its hard to put all that BB tq to the ground. Thats why the hopped up SB's usually run right with the BB's
Old Jul 1, 2003 | 05:52 PM
Corey_68's Avatar
Corey_68
Default Re: S/C SB or N/A BB? (Jvette73)
I'd go with the Big Block, nothing like lifting the hood and seeing a massive motor. :reddevil
And for those who doubt the fact that BB can handle, Chevy didn't race Small Blocks at LeMans, it was the 427 L88. And it won..... :D
Old Jul 1, 2003 | 06:01 PM
Schmucker's Avatar
Schmucker
I remember reading an article about a comparison between a 400 small block and a 400 big block. In the end the big block made more power, but it cost more. The small block made less power, but with the cost savings a supercharger could have been bought and more power could be made then the big block. I think small blocks are better for pretty much any situation. I really can't think of one where a big block would be better. Small blocks can make just as much power. A supercharged small block is the absolute best way to go. Don't forgot to look into a screw supercharger too, they are more efficient and provide better power throughout the curve over a centrifugal, but centrifugals can feed more air in at the higher RPMs, but it really depends on how large of a screw blower you get.
Old Jul 1, 2003 | 06:06 PM
Corey_68's Avatar
Corey_68
Default Re: S/C SB or N/A BB? (Schmucker)
So you're saying Top Fuel Dragsters should scrap the Big Blocks and switch to small blocks? :skep:
I will say that each has their place, but to say a Big Block is absolete is just well.......wrong.
Old Jul 1, 2003 | 06:56 PM
evilsmf's Avatar
evilsmf
BIG block Supercharged :thumbs:
[Modified by evilsmf, 5:18 PM 7/11/2003]
Old Jul 1, 2003 | 07:01 PM
1Bad69's Avatar
1Bad69
are you talking the HP at the wheels or at the crank?
if it is at the motor then would a small block with supercharger be more cash then a mildly built BB?
if you want to spend the cash on a small block and have a s/c for the sake of saying it is s/c'd..then sure...but if you just want those numbers i would go BB..a mild one will give you those numbers no problem....throw a s/c on a BB if you want.. :thumbs:
i have plenty of torque i think, and have no problems putting it to the pavement...just ask anyone that's been in my car...
[Modified by 1bad69, 7:04 PM 7/1/2003]
To S/C SB or N/A BB?
