Rear gear lube
Old Jul 1, 2003 | 09:46 PM
hauk's Avatar
hauk
Default Rear gear lube
What kind of lube should I put in the differential of 73 automatic coupe and how do I do it? I have a very slight pinion seal leak and would like to top it off. Thanks :confused:
[Modified by hauk, 10:00 PM 7/1/2003]
[Modified by hauk, 10:01 PM 7/1/2003]
[Modified by hauk, 9:33 AM 7/2/2003]
Old Jul 1, 2003 | 10:41 PM
PRNDL's Avatar
PRNDL
Default Re: Rear gear lube (hauk)
What kind of lube should I put in the differential of 73 automatic coupe and how do I do it? Thanks :confused:
Many have their favorite brand of synthetic, but it's hard to beat the GM differential lube, available from your GM dealer. Don't forget to add the GM positraction additive, also known as limited slip differential additive, 1 or 2 tubes depending on which size tube you get.
Step 1 is remove the old crap, ideally with some type of suction apparatus, either a suction pump or a turkey baster. Access is much easier if you remove the passenger side rear wheel. Then put in the additive. Then put in the differential oil until it dribbles out the top. I put a length of clear plastic hose on the top of my oil bottle and squeeze it out, and into the oil fill hole. :) MJ
[Modified by MNJack, 10:42 PM 7/1/2003]
Old Jul 2, 2003 | 06:34 AM
hunt4cleanair's Avatar
hunt4cleanair
Default Re: Rear gear lube (MNJack)
I just got all the stuff and will be doing this week...got the suction gun from NAPA for $12.00 and the lube and additive from Chevy dealer.
Old Jul 2, 2003 | 09:35 AM
baja216's Avatar
baja216
I've got an '80 that I just bought and I want to change the fluid in mine as well. From what I have read the 1980's had posi traction. When I looked at my rear end there's a red tag on there stating that I should refill it with limited slip. Is there a difference between the posi traction additive and "limited slip" additive?
Thanks for the help.
:auto:
Old Jul 2, 2003 | 09:43 AM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Bill,
Positraction is the name GM used to market its limited slip differential, so yes, they are the same. Other manufacturers used different marketing names for their limited slip diferentials.
Use a good 80-90W gear oil with a GL-5 rating in your differential and you'll be just fine.
For all the hype it gets, the GM positraction additive isn't all that great... Try the Ford limited slip additive, I'm pretty sure the part number is C8AZ-19B546A... Much better than what GM sells.
Regards,
Old Jul 2, 2003 | 12:15 PM
mapman's Avatar
mapman
I use the GM differential lubricant as specified in your owner's manual and shop manual. The Limited-Slip Differential Lubricant Additive GM 1052358 is important to add (first).
Incidentally, the additive part number for my 2003 EB convertible is the same as my 1980 - must be needed and it must work ok.
Old Jul 2, 2003 | 12:18 PM
PRNDL's Avatar
PRNDL
Default Re: Rear gear lube (Rowdy Rat)
Regards,
Heresey!!!!!! :lol:
Actually, one confusing thing as you try to learn this stuff - All you read about is "POSI-additive, posi, posi, posi, dont forget the GM POSI-additive" and then you buy the stuff from the GM dealer and the letters "POSI" do not appear on the tube! It is called "limited slip differential" additive. So until you figure out they are the same thing it is a bit confusing! :) MJ
Old Jul 2, 2003 | 12:24 PM
Neo Fender's Avatar
Neo Fender
Default Re: Rear gear lube (baja216)
Limited slip (posi-traction) differentials have been standard on C3s since 1970. They were optional for 1968-69.
Old Jul 2, 2003 | 01:06 PM
desi's Avatar
desi
:iagree: :iagree: :iagree: Very well said...
Old Jul 2, 2003 | 02:54 PM
Rowdy Rat's Avatar
Rowdy Rat
Heresey!!!!!! :lol:
Sorry MJ, I call 'em as I see 'em! :)
Anyone who knows me is aware that I purchase GM parts for my restorations whenever I can... But if someone says they have a "better mousetrap", I'm willing to give it a try if the claims look reasonable. Currently, the Ford limited slip additive is a better product than what GM offers. I can think of a few shops out there that agree with me on this so I haven't gone over the edge just yet.
I guess that this is a bad time to bring up Ford DOT 3 brake fluid? :)
Regards,
Old Jul 2, 2003 | 04:44 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
I guess I'll be the first to state that I use Mobil One synthetic. The stuff is great for all kinds of reasons and you don't need any additives. I had a clutch chatter problem when I first got the car. I changed to Mobil One and (after a few tight turns in a parking lot) it went away. 50,000 happy miles later and it's still going strong. Don't forget to do the 5 to 7 tight turns in each direction after you get the new oil in. It helps lube the clutches with the new oil.
Old Jul 2, 2003 | 05:51 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Default Re: Rear gear lube (burners)
i don't like running the limited slip additive. I kinda like the way the rear end jerks and clunks when going around tight corners. lets you know your posi is grabbing good.
Old Jul 2, 2003 | 07:19 PM
mapman's Avatar
mapman
Default Re: Rear gear lube (turtlevette)
:lol: :lol: :lol: :lol: :lol:
Old Jul 2, 2003 | 07:31 PM
RJR99SS's Avatar
RJR99SS
yeah i use mobil-1 synthetic too, even though it is pretty damn pricey and hard to find. I've always noticed that the rear end felt alot smoother in anything i put mobil-1 synthetic into the rear.
As for how to do it, you might as well just buy a rear end cover gasket along with the oil. Then you just put a pan under the rear end and take the cover off.
Scrap all the old gasket off, put the new one on. I like to use brake cleaner to clean the gears up in the rear, to get rid of any gunk or metal shavings in there. Then reinstall the cover. This way, you'll have the satisfaction of knowing you have a good gasket back there.
Getting fluid in the rear end is the hard part. The easiest thing is to just buy one of those cheap fluid pumps you see at the parts store and pump it from the container into the rear end.
Old Jul 2, 2003 | 08:02 PM
dman535's Avatar
dman535
Default Re: Rear gear lube (RJR99SS)
I just did a switch to Redline 75W90 synthetic. I run it in the BMW and its reallly great stuff. It comes with the Limited Slip additive already mixed in. Great Stuff.
Old Jul 3, 2003 | 04:50 AM
Rockn-Roll's Avatar
Rockn-Roll
I use Pennzoil or Valvoline 80-W90 GL-5 Gear Oil and the limited slip additive. What I do is pour out a little bit of oil out of each quart and squirt half the additive in each bottle. I then shake the bottles up real good to mix the additive up. This will save some possible wear on the gears, and will avoid any need for a break-in period.
Old Jul 3, 2003 | 05:04 AM
hunt4cleanair
RJR:
To replace the gasket...how much of the rearend did you have to dismantle?
To Rear gear lube
Old Jul 3, 2003 | 07:26 AM
mountainmotor's Avatar
mountainmotor
[b]
Regards,
Yes the Ford additive is superior in that the additive is in a either TMP or PE Ester carrier oil and the price is only $3.60 per bottle. Only one is needed and will blend with any gear lube. If the rear differential is already broke in" most are well broke in :D" and drained of all shavings and other contaminates using this should be good for 10 years or more especially if used with Conoco,Mobil or Pennzoil Synthetic gear lube if not raced regularly.
Old Jul 3, 2003 | 08:19 AM
pws69's Avatar
pws69
Riiiight........
Old Jul 3, 2003 | 10:00 AM
mvftw's Avatar
mvftw
Default Re: Rear gear lube (Rockn-Roll)
I just changed my rear fluid, I spilled about 1 oz of the 4 oz additive. Would adding another 4 oz's hurt, help, or make no diiference? Or just add half the bootle?
