'68 L79 Cam Specs
Old Jul 2, 2003 | 11:50 PM
Diode's Avatar
Diode
Default '68 L79 Cam Specs
Does anyone have, or know where I can get, the specs for the original '68 L79 cam? I just bought this car and part of the 'documentation' is a Spec Card from Competition Cams. The manual that I have only gives the lobe lift. The Spec Card shows that this number is different from the original (the Competition Cam lobe lift is .0045 more than the original). Not that it matters much, but I'm curious as to how much the duration, timing and overlap also differs from the factory cam. Thanks folks.
