updating distributor
Old Jul 4, 2003 | 01:38 PM
TRAVIS74's Avatar
TRAVIS74
Default updating distributor
I have been thinking of installing a more modern style distributor but I have a mechanical tach drive and am not sure if this is possible. I've looked at one in Ecklers catalog at a whopping 500 plus. I was hoping to do it for a little less. Thanks Travis :flag
Old Jul 4, 2003 | 02:08 PM
redvetracr's Avatar
redvetracr
Default Re: updating distributor (TRAVIS74)
Check out Mallory "Unilite" or the "Pertronix".
...redvetracr
Old Jul 4, 2003 | 02:32 PM
Jvette73's Avatar
Jvette73
Some people dont like em but ive had good sucess with the Pertronix II conversion kit. It converts your point style dist to breakerless electrinic. slap on a 50k volt canister coil and yur sparkin hot and good to go. Plus you can still carry the points along and slap em back in if the ignitor fails. ive never had to though. But its nice to have a back up in a simple ziplock baggie.
Old Jul 5, 2003 | 07:51 AM
WESCH's Avatar
WESCH
Default Re: updating distributor (Jvette73)
:iagree:
Yes, PERTRONIX is fine. I have the older one, but works OK.
I overhauled the ditributor in the mean time.
New bushings, new main shaft , drilled some extra lubrication holes to pressure lube the lower bushing and drive. ( was a recommendation on this forum ) :cool:
+ PERTRONIX is not expensive.
Good luck . Gunther
Old Jul 5, 2003 | 07:06 PM
Matt Gruber's Avatar
Matt Gruber
:iagree: except i use the #1181
Old Jul 7, 2003 | 08:49 AM
CircleW-72's Avatar
CircleW-72
I have the crane electronic conversion kit in mine with a MSD coil,works great and has a rev-limiter also! :yesnod:
Old Jul 7, 2003 | 02:57 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
I installed the Breakerless SE on mine this past weekend. More on the install later.
Old Jul 7, 2003 | 03:48 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: updating distributor (BlueL36)
look at the Crane. You don't remove anything except the points.
www.cranecams.com/ignition/xri.htm
Old Jul 7, 2003 | 03:54 PM
Alwyn678's Avatar
Alwyn678
Default Re: updating distributor (Mike Mercury)
http://store.summitracing.com/partde...=MAA%2D2664501
This is what I went with after having my Pertronix II module leave me stranded...Great performance , Great price, and it looks great
Old Jul 7, 2003 | 04:06 PM
pws69's Avatar
pws69
Default Re: updating distributor (Matt Gruber)
:iagree: except i use the #1181 Some people dont like em but ive had good sucess with the Pertronix II conversion kit. It converts your point style dist to breakerless electrinic. slap on a 50k volt canister coil and yur sparkin hot and good to go. Plus you can still carry the points along and slap em back in if the ignitor fails. ive never had to though. But its nice to have a back up in a simple ziplock baggie.
:iagree:
I have the older one (wait a few seconds before START - teaches me patience!). Went all through the dist. (index was 180 off, etc.) and put a Lars kit in it. Been great so far - but I do have a new set of points and condenser with me at all times because other folks here made me paranoid!!
To updating distributor
