Can you identify this object? (Plus mouse nest)
Old Jul 6, 2003 | 03:26 PM
69stingray's Avatar
69stingray
Default Can you identify this object? (Plus mouse nest)
I finally got around to removing my passeneger side seat and this is what I found under it, a nice cozy nest, wonderfull.
I also found this:
It is a bar about 8 inches long, made of a soft flexible metal. It is divided into squares qhich read 1/4"
Old Jul 6, 2003 | 03:31 PM
isosceles's Avatar
isosceles
Default Re: Can you identify this object? (69stingray)
those look like stick-on wheel weights. Bubba must've used them to offset the weight of the driver with no passenger in the car to fine tune weight distribution.
Old Jul 6, 2003 | 03:32 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
That looks to be a strip of glue on lead weights for wheels to balance them. It should have a 2 sided tape strip on the back, or may have at one time.
Some use glue on weights on the inside of the wheel instead of the clip on weights which mar the finish of the rim portion.
EDIT: hmmm -- someone answered as I was typing.....
[Modified by BSeery, 1:33 PM 7/6/2003]
Old Jul 6, 2003 | 03:35 PM
Larry B.'s Avatar
Larry B.
The metal bar is lead, divided into 1/4 oz. segments. It may also have a sticky back. They (some tire shops) use them for stick on tire weight. I have seen them in hobby shops also.
Old Jul 6, 2003 | 03:46 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Can you identify this object? (bluevetteman)
yup, balancing lead w/ adhesive backing.
Old Jul 6, 2003 | 07:11 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Can you identify this object? (Twin_Turbo)
Looks like enough change under there to pay for the vacuum cleaner at the car wash too. Nice find. :jester
Old Jul 6, 2003 | 08:46 PM
PRNDL's Avatar
PRNDL
I think it's some kind of a mouse trap! :lol: MJ
To Can you identify this object? (Plus mouse nest)
