Difficult shifting 4 speed ........
Old Jul 10, 2003 | 05:15 PM
BB68Vett's Avatar
BB68Vett
Default Re: Difficult shifting 4 speed ........ (75Rag)
I am glad it worked out. Be thankful for the easy fixes.
Old Jul 10, 2003 | 06:47 PM
75Rag's Avatar
75Rag
Default Re: Difficult shifting 4 speed ........ (BB68Vett)
Amen Brother!! Thanks for all the suggestions guys .... the collective forum "genius" strikes again! :thumbs:
Old Jul 10, 2003 | 09:44 PM
Clink69's Avatar
Clink69
Default Re: Difficult shifting 4 speed ........ (bence13_33)
Most likely it's the shifter linkage or the clutch. A clutch that is out of adjustment will make it difficult to shift gears. Was it wanting to grind the gears? If not, it's the shifter linkage. The rods could be binding up or the bolts that hold the linkage in place could have loosened up. It has happened to me before.
:iagree: characterstic of both of these.... Also check the shifter bolts while your checking, my loose shifter bolts made it difficult to shift..
