Evaporator/Blower housing
Old Jul 12, 2003 | 05:29 PM
ugman's Avatar
ugman
Default Evaporator/Blower housing
Can anyone tell me if the blower should be on when if the heat/air is off?
Everyting is off and I turn the key to gen so that I can listen to the radio, and the fan in the blower housing is on.
Old Jul 12, 2003 | 05:47 PM
isosceles's Avatar
isosceles
Default Re: Evaporator/Blower housing (ugman)
I think so. My is always on low speed, even if A/C-heat-defrost switch is off.
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Yes, it is supposed to be on. Pizz poor way of doing things but that's the way Chevy did it.
Old Jul 12, 2003 | 06:08 PM
Roadster71's Avatar
Roadster71
Default Re: Evaporator/Blower housing (Smokehouse69)
The blower on my wife"s 82 doesn't work at all, although the air cond still does. Replaced the console switch but no luck. Where should I check next?
[Modified by Roadster71, 6:09 PM 7/12/2003]
Old Jul 12, 2003 | 06:12 PM
ugman's Avatar
ugman
Thanks. I also found a huge crack in the plastic housing. I hope 9 layers of duct tape will surfice for now :-)
Old Jul 12, 2003 | 11:23 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Default Re: Evaporator/Blower housing (Roadster71)
Try the resistors mounted in the air stream of the blower housing under the hood. These are what allows slow and medium speeds. There is also a blower relay for high speed that could be faulty (also under the hood) and of course check the ground to the fan.
[Modified by Big Fish, 10:24 PM 7/12/2003]
[Modified by Big Fish, 10:26 PM 7/12/2003]
Old Jul 13, 2003 | 12:04 AM
Diode's Avatar
Diode
Default Re: Evaporator/Blower housing (Big Fish)
2 things…the blower should be on. There is a switch called the "low blo switch" that turns the blower fan on "Low" speed even when the fan switch is in the "Off" position if the temp control is set at anything other than "Off" or "Vent". This is part of the "Astro Ventilation" system. It's located on the climate controls unit and is controlled by the temp control. Second (blower not working) there is an in-line fuse between the "BAT" terminal on the horn relay and the blower relay that needs to be checked. Also, the 2 main culprits of the blower not working are (1) the blower relay and (2) the blower speed control resistors, in that order.
Old Jul 13, 2003 | 10:43 AM
Ganey's Avatar
Ganey
Blower A/C Vent
Low to Off
Disconnect connector at resistor box under hood pass. side near high blower relay & bend down the connector to dk. brown wire & reconnect. (77)
Changed mine many years ago.
:cool:
Old Jul 13, 2003 | 09:19 PM
Roadster71's Avatar
Roadster71
Default Re: Evaporator/Blower housing (Ganey)
What does that do?
Old Jul 13, 2003 | 10:08 PM
dogboy's Avatar
dogboy
That will stop the blower from working all the time. It will work only if you move the fan lever to low, med, or high.
To Evaporator/Blower housing
