engine identification Guru's
Old Jul 13, 2003 | 10:44 PM
Mike Mercury's Avatar
Mike Mercury
Default engine identification Guru's
I'm trying to nail down the engine ID for the wIfes 1973 small block.
Here are the numbers on the block:
rear of block - drivers side 3970010
front of block-passenger side- in front of head:
K03 11 CNO
also: 101163836
I've looked at the many web sites that list Chevy suffix codes, but they skip over the "CNO" suffix. Maybe it's not a Chevy engine ??????
Help!!!!
Old Jul 13, 2003 | 11:19 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: engine identification Guru's (Mike Mercury)
I come up with a 1968 327 cu in. 2 bolt main.
Possibly out of a GMC truck or a pontiac.
Old Jul 13, 2003 | 11:33 PM
Mike Mercury
Default Re: engine identification Guru's (LAvetteman)
just about everything I find for 3970010 says it's a 350 cu in.
:confused:
Old Jul 13, 2003 | 11:43 PM
LAvetteman's Avatar
LAvetteman
Hmmm, you are right, actually it has that number listed for both 327 and 350.
Check it out: http://www.nastyz28.com/sbchevy/sblock.html
Old Jul 13, 2003 | 11:44 PM
Crash Dummy's Avatar
Crash Dummy
Mike,
I pulled out my old '66-'73 Chilton's Car Manual and cannot find a *CNO* extension on any GM car. Might possibly be a truck block. All of the *CN's* appear to be '70 engines and the closest things I could find were CNQ & CND. Both were vette blocks(350's).
(Edit)- added (350's)
[Modified by bgrice, 10:48 PM 7/13/2003]
Old Jul 13, 2003 | 11:52 PM
boredsoIstrokedit's Avatar
boredsoIstrokedit
3970010 is the 4" bore large journal block. 350, 327, 302. Can't help you with anything else, though. Good luck.
Old Jul 14, 2003 | 12:06 AM
Mike Mercury
Default Re: engine identification Guru's (boredsoIstrokedit)
you guys are great and helpful. I am stumoped with the "CNO".
I've triple checked it and it certainly looks to be a CNO and not a CNQ.
The engine runs exceptionally strong and the car is a blast to drive.
But oh the mystery... :)
Old Jul 14, 2003 | 12:08 AM
Mike Ward's Avatar
Mike Ward
The give away on this is the letter "K" at the beginning of the stamp pad. That means the block was cast at the McKinnon foundry in St. Catherines Ontario.
Not a Corvette block.
Old Jul 14, 2003 | 01:00 AM
Mike Mercury
Default Re: engine identification Guru's (Mike Ward)
Ah Ha! Mike Ward to the rescue. Any clue as to what models the McKinnon foundry made blocks for in that era?
[Modified by Mike Mercury, 12:01 AM 7/14/2003]
To engine identification Guru's
