How do I remove the rear Caliper?
Old Jul 16, 2003 | 09:23 PM
battsup's Avatar
battsup
Default Re: How do I remove the rear Caliper? (Brettmc)
Ok the problem seems to be that the part of the frame that the is underneath(horizontally) the bolts that hold the caliper has either come up or the caliper part(vertical) has somehow sustained a blow and come down. That is the reason why the socket won't fit. I verified this by checking the side i dont need to fix and it holds true. So how do i unbend my frame :eek: . Sorry i can;t post a pic until sunday, my dads gone on a business trip and he took the digital cam with him.
Old Jul 17, 2003 | 09:59 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
Default Re: How do I remove the rear Caliper? (battsup)
I use an impact ratchet wrench on mine. Because air tools kind of "bang" at the bolt, it breaks tehm loose without stripping. In other cases I have gotten a 12"breaker bar on them, but clearance is tight, so it is sometimes hard to manuver. :smash: :mad :smash: :mad
Old Jul 17, 2003 | 10:08 AM
rexx78's Avatar
rexx78
That sounds like a problem you have here. Like everyone else, I used a socket and impact wrench. I had to remove the brake line first.
Heat it up and bend it back very carefully. We may be more help when you post a picture.
Old Jul 17, 2003 | 10:31 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: How do I remove the rear Caliper? (rexx78)
?? Has the caliper bracket moved? That's weird, it's held by the 4 hub studs. It's also a cast piece, it does not bend (but breaks easily) something sound very wrong here.
I don't have a pic w/ the stock caliper on but this should give you an idea.
NOTE! The bolts that hold the bracket are not stock, normally the 4 studs on the trailing arm go through there.
[Modified by Twin_Turbo, 9:32 AM 7/17/2003]
Old Jul 17, 2003 | 10:59 PM
battsup's Avatar
battsup
ok ill post pics on sunday, can't do anything with the brakes til then anyways cuz the rebuild kit wont get here til tuesday
