Is this too wide a tire?
Old Jul 16, 2003 | 03:28 PM
dudeskie's Avatar
dudeskie
Default Is this too wide a tire?
I need to get new tires for my 79. I was thinking about the BFGoodrich Comp T/A drag radials but the thinnest they come in is 275/50P15. I need 15 inch wheel size but I was just trying to get people's idea of whether or not these tires would fit and not scrape against any suspension (stock save for the poly bushings) once mounted on my car. I think I would probably need a spacer if I wanted to get them...
Any help would be greatly appreciated
Old Jul 16, 2003 | 03:34 PM
1969Vette383's Avatar
1969Vette383
Default Re: Is this too wide a tire?
Now I may not be exactly the best person to chime in now, I've got 295/50-15 size rubber on all four corners. When I say that people go, :eek: "How did you fit that much rubber under the car?!" I've got fender flares in the rear and up front the fenders aren't '68-'69 style. I've got the '70-'72 style "egg crate" gills. These fenders have more of a flared lip than the '68-'69 style. Nothing rubs in back, though the fronts rub inside on the sway bar and outside on the fiberglass when turned hard.
I've heard, at least from other early C3s, that people are comfortable with a width of 265. I don't know if 275s will give you problems or not :confused: I'm not a '79 kinda guy :lol: :cheers: :chevy
[Modified by 1969Vette350, 12:39 PM 7/16/2003]
Old Jul 16, 2003 | 03:41 PM
Tominator's Avatar
Tominator
Default Re: Is this too wide a tire? (dudeskie)
I don't think those drag radials make a good street tire for daily use, but maybe someone will chime in that has them.
Here are my 295/50/15, but I have 3.5 backspacing
Also here are some pictures of tire widths 295-245-235
[Modified by Tominator, 2:47 PM 7/16/2003]
Old Jul 16, 2003 | 04:10 PM
dudeskie's Avatar
dudeskie
Another tire I am looking at is the Mickey Thompson Sportsman I at L-60 15. Bence has told me about the M/T before but I am still not sure if they will fit me...
Old Jul 16, 2003 | 04:12 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Don't use drag radials on the street.
They will wear out quickly and are very easily punctured.
Also, you hit one puddle and you will be in the ditch.
Old Jul 16, 2003 | 04:18 PM
dudeskie's Avatar
dudeskie
Default Re: Is this too wide a tire? (BSeery)
Would any one have a tire that they would recommend. I need something that has a little bit more stick than the traditional BFG Radial T/A. Wear isn't really an issue with me, I have a hook up that can get me cheap tires. He works for a tire manufacturing company that does business with companies such as Mickey Thompson.
Old Jul 16, 2003 | 06:13 PM
SC71LT1's Avatar
SC71LT1
I've run the MT ET Street and the BFG drag rads. Definately not good street tires: they wear quickly, are easily punctured and don't grip worth a damn on moist pavement. If you want more grip than the T/A Radial, check out Yokahoma and also a new tire from Pirelli called the P Zero Corsa. Good luck.
Old Jul 16, 2003 | 06:46 PM
toddalin's Avatar
toddalin
You could try a "sticky" autocross tire and, while it would wear out fairly quickly, would also be great on the street also. (Again, stay out of the puddles.) I've had much better launches with Yokahama 008Rs than the Goodyear gatorbacks (both 225/60/15) on my '64.
BTW, you can get the Goodrich drag radial in 235/60/15 and that would easily fit and they're even $4/tire cheaper than the 275/50s and $12/tire cheaper than the 275/60s at Summit.
Old Jul 16, 2003 | 08:46 PM
Clink69's Avatar
Clink69
I am running exactly that size Drag Nittos on mine all the time... Fit barely but don't rub... Worst case is you will have to move the Ebrake bracket....
Old Jul 16, 2003 | 09:03 PM
The Money Pit's Avatar
The Money Pit
Default Re: Is this too wide a tire? (Clink69)
I ran P295 50's on the stock alloy rims for a few years without clearance issues,but thaught they pinched on the rim a bit. I would have liked to widen the rim but had no luck finding a reputable shop that could do the work.
I now run Weld Draglites with the same size tires and I think the fit is next to perfect.I've run huge rear tires for years and for all the traction you gain on dry roads,you WILL lose on wet roads.Drag Radials are out of the question for me due to wet traction and short tread life.
[Modified by The Money Pit, 9:10 PM 7/16/2003]
Old Jul 16, 2003 | 09:10 PM
Dwayne 76's Avatar
Dwayne 76
The only problem with a wide tire is the rocks that are they're going to throw at the back fenders, at least thats a problem I have with my 275's
Old Jul 16, 2003 | 09:18 PM
jbroughton's Avatar
jbroughton
I've heard that the Nitto drag radials handle much better in the rain than the BFG's. They're supposedly very sticky, and still manage to wear decent. I've got the BFG's on my turbo Buick, and they are definitely an adventure if you get caught out in the rain. :eek:
Old Jul 16, 2003 | 10:04 PM
Dwayne 76's Avatar
Dwayne 76
Default Re: Is this too wide a tire? (jbroughton)
No kidding, I was caught in the rain with th BFG's on the 'Vette, anything over 80Km/hr felt like the car was going to loose it.
Old Jul 16, 2003 | 10:08 PM
Clink69's Avatar
Clink69
Default Re: Is this too wide a tire? (Dwayne 76)
It is an adventure to drive my car in the rain. I avoid this as much as possible...I used to have BFGs and I would say they are similar to the Nittos, both suck in Rain.
Old Jul 16, 2003 | 10:49 PM
munday's Avatar
munday
Toyo T1-S..... AWESOME TIRE!!!!!!! about the 255 is what I have in the back, it's a sticky tire and rocks!! The T1-s you can do over 100 in the rain (don't kill yourself) but I have done it and had very confident control.
I'm gonna try the nitto xtreme drags next on the back, but only because i had them on my lightning and they hook incredible off the line and the cornering is great too. The nitto i wouln't go over 65 in the rain prolly
:party:
[Modified by munday, 3:51 AM 7/17/2003]
munday's Avatar
munday
Default Re: Is this too wide a tire? (munday)
forgot to mention i'm running 17's
Old Jul 16, 2003 | 10:55 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
I run 275 60 15 BFG's and had to relow the E-bracket. They are very soft and one quick burst of the throttle will coat the rear of the car with black sut.
[Modified by Budman78, 9:57 PM 7/16/2003]
To Is this too wide a tire?
Old Jul 17, 2003 | 08:14 AM
norvalwilhelm's Avatar
norvalwilhelm
Took a little work but these are 305 radials under the fender. With Mickey Thompsons are they radial or bias ply?. I ran MT Sportsman Pro's for a few years and really liked them but they have short life on the street. They are a wrinkle walled tire. I them went to ET streets, had great traction but swayed when passing.
Rain? I never drive in the rain.
Old Jul 17, 2003 | 09:03 AM
75 Stingray!'s Avatar
75 Stingray!
Default Re: Is this too wide a tire? (norvalwilhelm)
What did you do to get those 305 to fit? Also what is the back spacing on your rim? Those tires look nice and stick out about as far as my 255 lol
Old Jul 17, 2003 | 09:26 AM
stinky's Avatar
stinky
Yeah, Norval, what the hell did ya do, bro????
