From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
dyno day for the vert
The 74 pounded out some good torque and sound. I guess the HP numbers are ok since I'm running a mild can and stock heads. I expect my compression ratio might be near stock. I was also able to verify that my four barrel is opening up, I believe it's opening slow.
movie, thanks Eddie 70 http://webpages.charter.net/bdavis1_tnx/MOV00015.MPG
run 1: 212.7hp 295.5 ft-lbs
run 2: 207.6hp 285.6 ft-lbs
run 3: 206.0hp 284.9 ft-lbs
I wonder what type of increase I would attain with aluminum heads and larger cam? Suggestions please?
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Re: dyno day for the vert (98Pace97Coupe)
Dyno was fun. I need to shoot my graph too. I didn't even think of doing it like you. Next time I go I will carry a video camera of some kind to get plenty of footage.
