Blower Wiring/Electrical Question (1982)
Old Jul 26, 2003 | 04:22 PM
Enad's Avatar
Enad
Default Blower Wiring/Electrical Question (1982)
Can anyone tell me why the heater blower motor has a 12 gauge
(3.0) positive wire and only a 16 gauge (1.0) ground?
I changed my blower and at the same time the ground wire to a
12 gauge. The fuse blew after a few minutes of "High" operation.
I can't say if the new wire is the problem but why is there a
difference in the wire size?
Dane
Old Jul 26, 2003 | 10:36 PM
Fleetwood's Avatar
Fleetwood
Default Re: Blower Wiring/Electrical Question (Enad)
Generally the current carrying capacity of the groung wire is at a lower potential than the feed wire in a balanced circuit,& is there to complete the circuit.The ground or neutral should be at earth potential,& should carry very little current.The size of the wire should not cause the fuse to blow,make sure you have the correct size fuse in,it should be either a 25A or a 30A.
If it still blows then there is a problem with the motor.
[Modified by Fleetwood, 9:39 PM 7/26/2003]
