Rich and Cold :-(
Old Jul 28, 2003 | 11:50 PM
djlangford's Avatar
djlangford
Default Rich and Cold :-(
For some reason, my '74 454 auto runs rich as can be when cold. Even to mid-temp it runs really crappy. It ran fine 'till a few weeks ago (I have little time to spend with her :cry ). So, I'm thinking either the pull off valve, or the choke (the thermostat-like thing on the intake, right?).
Or, would richness have to do with mixture? I thought the mixture screws adjusted for the whole range, idle and non-idle.
After everything gets up to operating temp, it runs just dandy.
Also, its an all stock Q-jet, I live in Las Vegas, at ~2,200 ft. It started running bad after the temps got above 100.
BTW, just got new photo, working on sig. If you are interested...
http://members.***.net/djlangford/072703-Corvette.htm
Thanks,
David :flag
Old Jul 29, 2003 | 12:47 AM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: Rich and Cold :-( (djlangford)
My guess, your choke needs to be adjusted to a lesser seting.
Old Jul 29, 2003 | 01:21 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Black on Black in Las Vegas? Man you gatta love corvettes to drive in that heat. :lol:
As for the "runs rich when cold and even to mid temps runs crappy ... after everythings warmed up ... its dandy" sounds like the choke blade isn't set right - closed to far. You need to get the books out (shop manual or whatever brand repair manual - yes can be found at local library) and find the adjustment for the choke. May have bend the choke rod for this (welcome to Q-jet ownership) to set choke valve/blade spacing. BTW Idle mixture screws adjust mixture at idle only while throttle blades (not the choke valve/blade) are shut or nearly shut. Rods and jets (or could say rods in thier jets) control mixture once off idle.
Now for every 2,000 ft altitude change Holley carburetors require a jet change (one number) and I assume the worst that Q-jets would too. If your fouling plugs or notice black exhaust smoke a step leaner is the way to go. :seeya
To Rich and Cold :-(
