Brake issues.....need help
Old Aug 1, 2003 | 02:47 PM
6T9VETT's Avatar
6T9VETT
Default Brake issues.....need help
After 20 minutes of driving the brakes start engaging on their own. After stopping for 30 minutes they let loose again. I bled the brake system, worked well for a day or so then it started again. Was wondering which angle I should try and tackle this from first? :banghead: :chevy
Old Aug 1, 2003 | 02:56 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: Brake issues.....need help (6T9VETT)
Often that is caused by the flexable brake hoses collapsing internally. If they are old its not a bad idea for good measure.
Old Aug 1, 2003 | 03:09 PM
HWY 9 - Z06's Avatar
HWY 9 - Z06
Sounds like your brake fluid level in the reservoir might bee to high. when everything gets hot and expands it can apply brake pressure. try loweing your level a little. You might be able to confirm this if while it is occuring, open the lid on the master cylinder, if brake fluid pours out, your level is definatley too high.
Old Aug 2, 2003 | 11:19 AM
6T9VETT's Avatar
6T9VETT
Default Re: Brake issues.....need help (HWY 9 - '69)
Thanks for the ideas....will check it out today when I get home from work. :cheers:
To Brake issues.....need help
