1980 Air Vent Selector Experts
Old Aug 3, 2003 | 11:24 AM
azswede1960's Avatar
azswede1960
Default 1980 Air Vent Selector Experts
Need some troubleshooting tips as all air is coming out of vents at my feet!!!
I understand the system is vaccum driven but don't have clue on how to check it as I don't understand the operation of the selector system.
Troubleshooting tips really needed!!! :confused:
Old Aug 3, 2003 | 02:31 PM
American Boy's Avatar
American Boy
Default Re: 1980 Air Vent Selector Experts (azswede1960)
Under the center console at the blower vent selector, there's a vacuum switch that control all the flaps. Look there, the selector is made of plastic and sometime, it can seperate and cause that problem.
Other than that, you have a vacuum source from the engine that enter by the firewall a little to the right side of the wiper motor. Check if the hose is in place.
Stephan
Old Aug 3, 2003 | 03:07 PM
Disco_Mike's Avatar
Disco_Mike
I have the same problem in my 79. here is how i checked it.
grap a vacuum testor/source. i used the one i bought for bleeding brakes.
remove the side tunnel panel from both sides.
using the assembly manual or vaccuum diagram, find the vacuum source line. verify that vacuum is present. if it is not, it is a whole in the line, bad check valve or something at the source. The selector for defrost is vacuum operated. 1st i verifed that i could move it manually. then i used the vacuum testor and verified that vacuum will move the actuator. all these tested out in my case. the only problem is with the switch. I do not know if it is rebuildable or not. I do not know if you can purchase just the switch. I do know you can purchase a whole swith assebly. when its cool and i need defrost i have a length of vacuum tubing connected to the defroster actuator. i use my vacuum pump to activate the actuator. and viola! defrost. i have enought hose that the vacuum tester rests on the center consol.
Mike
Old Aug 4, 2003 | 09:58 PM
azswede1960
Default Re: 1980 Air Vent Selector Experts (79Fever)
Okay - pumped vaccum into Defrost & Front Vents : WORKS :party:
Got good vaccum from source, but apparently not switching........
Think I need a rebuild kit from ZIP, but which one ?????
Old Aug 5, 2003 | 02:16 AM
CorvetteKid82's Avatar
CorvetteKid82
Same problem with mine, I plan to start tearing into it this weekend.. Vettes the daily driver now as the camaro is in the shop for a window motor (common problem).
Old Aug 5, 2003 | 02:38 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Mike
Shall we call you MISTER Bubba ?
Old Aug 17, 2003 | 01:38 PM
azswede1960
Default Re: 1980 Air Vent Selector Experts (American Boy)
Has anyone bought/rebuilt the vaccum switch ? I ordered the kit and wondered how tough of a job this is going to be
Old Aug 18, 2003 | 11:00 PM
azswede1960
Got it working - SWEET! Thanks a lot for advice. :party:
Old Aug 19, 2003 | 03:14 PM
CorvetteKid82
Mines functional again as well... it was a cracked vaccume line coming from the intake manifold. Replaced with a new hose and it works like a charm. :hurray:
To 1980 Air Vent Selector Experts
