1970-1972 a/c blower-fan
Old Aug 8, 2003 | 10:30 AM
Edu's71's Avatar
Edu's71
7th Gear
Default 1970-1972 a/c blower-fan
Hi there,
can I replace the blower/fan with something more eficient?
There is got to be some thing more powerfull to pull air.
Do you guys know of any aftermarquet product?
Eduardo
Old Aug 8, 2003 | 11:14 AM
mrvette's Avatar
mrvette
Default Re: 1970-1972 a/c blower-fan (eduardodenise)
First off, welcome to the forum....
Most of the guys seem to think a C4 motor and fan assy is the best mod, more airflow/efficiency...and needs a spacer since the fan is deeper...about 3/4 inch seems right, I think....
what you may want to do though, is make damn sure you are getting FULL system voltage to the fan assy you have now, on high speed...if not...you can maybe say 1/2 a volt less is normal...anything more than that and you need look at just where the voltage drops are coming from....
GENE
Old Aug 8, 2003 | 11:38 AM
Edu's71's Avatar
Edu's71
7th Gear
Default Re: 1970-1972 a/c blower-fan (mrvette)
Thank you so much for your welcoming & help!
Just any C4 blower/fan or a specific year?
Thank you again.
Eduardo
Old Aug 8, 2003 | 06:47 PM
goofygrin's Avatar
goofygrin
Default Re: 1970-1972 a/c blower-fan (Edu's71)
I think there are some postings about this on http://www.corvettefaq.com with pictures and stuff. You might want to check there...
Old Aug 9, 2003 | 02:01 AM
Edu's71's Avatar
Edu's71
7th Gear
Default Re: 1970-1972 a/c blower-fan (goofygrin)
Hi there,
Thank you so so much guys, I just read the post on FAQ.
Exactly what I was looking for.
Eduardo :hurray:
To 1970-1972 a/c blower-fan
