Amp Ground '79
Old Aug 9, 2003 | 10:09 PM
shutout31's Avatar
shutout31
Cruising
Default Amp Ground '79
I am putting in an amp that is right against the back wall on a '79 vette, where can I ground it at? Thanks in advance.
- Scott
Old Aug 9, 2003 | 10:57 PM
Sun King's Avatar
Sun King
Default Re: Amp Ground '79 (shutout31)
Are you hearing impared? Just don't do it. Wifey's 79 had one in the same place and it killed the battery. I'll suggest drilling through the floor (very small[obviously]) and grounding to the frame.
Old Aug 10, 2003 | 02:15 AM
mapman's Avatar
mapman
Look under the car for the rear frame cross piece. The tail/stop lights are grounded there. Should be on the driver's side.
To Amp Ground '79
