'82 owners-please help
Old Aug 12, 2003 | 03:36 PM
Magnum '82's Avatar
Magnum '82
Default '82 owners-please help
Perhaps some of you have read my posts-I am having some tuning problems and need feedback.
Please check your rpm's at cold start and report back. Here is what mine is doing: Outside temp is at 75. Cold engine start-1700 rpm's for 1 minute, then it takes 1 minute more to drop to the 1000 rpm mark, then one more minute again for it to finally drop to 800 rpm. I fail to believe this is how it should be. I'm sure GM knows people don't have the patience to sit and warm up an engine like that. Just imagine if it were really cold out! In comparison my truck cold starts at 1000 rpm for only about 2 seconds and then levels out at 800 rpm. I have been dicking around with this thing for way too long now and am about ready to put it on e-bay :smash:
[Modified by Magnum '82, 2:37 PM 8/12/2003]
Old Aug 12, 2003 | 05:05 PM
page62's Avatar
page62
Default Re: '82 owners-please help (Magnum '82)
:confused: I'm not sure about a Cross-Fire Injection car, but those of us who have carburetors would consider these numbers perfectly normal!
Old Aug 12, 2003 | 05:09 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: '82 owners-please help (page62)
1700 rpm in open loop is way too high, it should be around 1000, 1200 max.
Normal idle rpm is anywhere between 700 and about 900, depends on whatt he car likes best.
Sounds like it's time to check for vac leaks and rebalance those TB's.
Old Aug 12, 2003 | 05:10 PM
Fevre's Avatar
Fevre
What you need is the stock warm up table, it will tell you what rpm the eng is programmed to run at at a specific coolant temp. Then you can work from there.
Old Aug 14, 2003 | 02:36 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: '82 owners-please help (Fevre)
Cold start here (which is about 95 degrees) I get about 1000RPMs then after about a minute, I'm down to about 850....
Yeah our low yesterday was 95, but it keeps all the thick blooded people away. :thumbs:
To '82 owners-please help
