Fuel Delivery Problem
Old Aug 13, 2003 | 12:52 AM
Indy Year 25's Avatar
Indy Year 25
Default Fuel Delivery Problem
My 78 doesn't pump any gas when cranking it. Any ideas?
If you prime it, it starts right up and runs well except it lays down when it shifts to 3rd at WOT.
Old Aug 16, 2003 | 11:38 AM
snb73's Avatar
snb73
Default Re: Fuel Delivery Problem (Indy Year 25)
Indy Year 25,
I had a fuel delivery problem too, found out it was a clogged "fuel sock" in the tank.
http://forums.corvetteforum.com/zerothread?id=626996
I hope this helps.
Good luck, Steve.
Old Aug 16, 2003 | 07:31 PM
Indy Year 25
Default Re: Fuel Delivery Problem (snb73)
Thanks Steve! I will try poking it with a stick............like road kill.
Anyone know if I can change the sock fairly easily on my 78?
Old Aug 16, 2003 | 07:35 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Get the spare tire carrier out of the way and you can then get at the sender and sock. Are you sure the fuel pump is ok? Or the filter to the carb?
Old Aug 16, 2003 | 10:06 PM
Indy Year 25
Default Re: Fuel Delivery Problem (biltogo)
:yesnod: I just changed the fuel pump for the second time since I started having the lay down problem. (Don't ask why I changed it the second time. :bb )
The filter in the carb has been changed too (and the carb has been rebuilt). Besides, when the line is disconnected from the filter it won't pump gas when cranking.
[Modified by Indy Year 25, 10:07 PM 8/16/2003]
Old Aug 17, 2003 | 01:18 AM
AlwaysWave's Avatar
AlwaysWave
If you diconnect the gas line TO the pump, does gas weep from the line? If not, then as you already surmised, the problem is upstream.
Old Aug 17, 2003 | 10:04 AM
Indy Year 25
When I replaced the fuel pump gas did not weep out of the line FROM the tank.
Old Aug 17, 2003 | 11:54 PM
Indy Year 25
Can I do this with a small amount of gas in the tank?
To Fuel Delivery Problem
