Installing Harmonic Balancer?
Old Aug 14, 2003 | 01:57 PM
JB's Avatar
JB
St. Jude Contributor
Default Re: Installing Harmonic Balancer? (Tom454)
Thanks for the links, Tom, but those danged things cost $35 + shipping! I bought a length of threaded rod and the appropriate nuts and washers for $2.30, though now I do have to break out the grinder and cut off discs to cut the rod down to a size that will fit between my radiator and the crank.
JB
Old Aug 14, 2003 | 01:58 PM
JB's Avatar
JB
Default Re: Installing Harmonic Balancer? (mrvette)
frankly I bang with care and tenderness, and have never broken a rubber yet....
GENE
:rofl: I'm sure your wife appreciates that, Gene!
JB
[Modified by JB, 1:00 PM 8/14/2003]
Old Aug 14, 2003 | 02:01 PM
mrvette's Avatar
mrvette
Default Re: Installing Harmonic Balancer? (JB)
sometimes is have a problem fitting my tool between the cracks....no the cranks and the hot spot....no.....
oh nevermind....
GENE
Old Aug 14, 2003 | 03:28 PM
Tom454's Avatar
Tom454
The first time I did it, my rubber broke.
So I got a better tool.
Seriously... Gene.. you won't necessarily see the damage when you do the install. It usually worsens over time and the outer ring eventually slips and/or falls off. Several members of this forum have posted links to pics of failed dampers. Many have found their outer rings have slipped. (ouch)
It's usually a gradual process from time of abuse to melt down. If you check out any of the popular reference books on rebuilding engines, they all warn against hammering on harmonic balancers. I have plenty of fine examples of abused balancers in my "show & tell" box.
So... if you abuse your balancer, your rubber might fail, and your ring might slip.
If it's not too tight a fit, you might get away with pounding it.
:jester
Old Aug 14, 2003 | 03:46 PM
Barry's70LT1's Avatar
Barry's70LT1
Simple home made tool.
Weld two bolts together. Fully thread into crank.
Use nut/washer to install balancer.
Barry
Old Aug 14, 2003 | 06:26 PM
A C's Avatar
A C
Cruise-In II Veteran
:iagree: Not really a problem until you find out that the wacky timing problem you have been chasing for a couple of hours is just a slipped outer ring (along with it's timing mark that ended up underneath the waterpump somewhere).
My next balancer will be one of those fluid ones....where there IS no outer ring. :D
Old Aug 14, 2003 | 07:46 PM
wayne_69_427's Avatar
wayne_69_427
Use a long bolt that is bottomed out in the crank use a couple of washers and nut to draw the pulley on to the crank. It is the same a putting on a power steering pump pully just a little bigger. good luck
