Re: List the Top 3 Problems with your Vette... (Jack71)
All Mechanical (go figure...)
1) Internal engine oil leak (intake gaskets need to be replaced)
2) Steering Gear grease leak (need to rebuild)
3) Power Steering system leaking (need to rebuild)
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Re: List the Top 3 Problems with your Vette... (TedH)
We only get to list three things....too bad.
1. Gotta get this thing painted!!!!!!!
2. Interior needs it all done!!!!!!!!
3. I would like to have a top made of the material that the new corvettes tops are made of.
I would like some great new wheels after the repaint, etc....Hopefully I will never become bored tinkering with it.
Re: List the Top 3 Problems with your Vette... (Brettmc)
1. Fresh TH400 won't lock into low, put it in 1st and it starts out in third????
2. Still leaks after new weatherstrip.
3. Bubba paint job. Thank God it's white!
I need more than 3 spaces. At least it's fast now.
1) cracks and chips in original paint.
2) uses/leaks too much oil for my taste (1 quart every 500 - 1000 miles)
3) NEEDS MORE POWER :yesnod:
3.5) clock doesn't work.
1. Gas tank just started leaking :cry Luckly its not the tank but the vapor canister rubber lines :thumbs: but I still have to drop the tank to fix it. :cry
2. Noisy old tired tranny. Used to be top priority but I think a leaky gas tank comes first. :yesnod:
3. need new rear spring.
1) The F___ing body shop won't get it done so I can have it back on the road.
2) I hate the console
3) It needs AC fixed, Alarm and keyless entry installed ...also misc. parts onhand: hi vol water and fuel pumps, monospring, new valve covers.
#1 is the biggest PITA ...they have had it since January. Believe it or not. The problem is they are SORTOF doing me a favor. A major fender bender turned into an all body paint job. I hope its done soon! Black. I replaced motor, trans, and rebuilt almost everything. Still not done breakin. It should be coming back a new car! SOON!
