TH400 transmission
Old Aug 15, 2003 | 10:36 PM
OkieVett's Avatar
OkieVett
Default TH400 transmission
Have got alot of great info for a long time from this forum. Now I must ask a question. Drove my 71 yesterday, shut it off came back out and the transmission was shifting at high RPM and going through the gears really hard. I would have to be going 60 to go into 3rd. No vaccum leaks, changed the modulator valve, fluid is good, still the same. Any advice
Old Aug 15, 2003 | 11:07 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: TH400 transmission (OkieVett)
Yes, no vacuum to the modulator...
or bad modulator...
Check it again.
Old Aug 15, 2003 | 11:49 PM
OkieVett's Avatar
OkieVett
Default Re: TH400 transmission (427V8)
Once again this forum has saved the day. You are correct 427V8, I started disconnecting vaccum lines and found the headlights all of a sudden have a leak somewhere, capped them off and now the transmission shifts like normal. Will fix the headlight leak tomorrow.
Old Aug 16, 2003 | 12:19 AM
427V8's Avatar
427V8
:party: :party: :party:
I knew something! I knew something!
BTW I've been bitten by that problem many many times to miss it again!
To TH400 transmission
