Check your alternator impeller fan.
Old Aug 19, 2003 | 06:43 PM
gdh's Avatar
gdh
Default Check your alternator impeller fan.
I started hearing a strange noise the other day under the hood, turned out the fan attached to the alternator pulley was loose, tried tightening and still noise. Thought it could be a bearing but when I took it off there was a crack in center leading outwards. I have heard from others who have had a similar noise and replaced the entire alternator.
Old Aug 19, 2003 | 06:51 PM
Hobbes Blk '80's Avatar
Hobbes Blk '80
Default Re: Check your alternator impeller fan. (gdh)
Nice tip.
Keep an Eye on those U-Joints too guys, god knows how pretty those can get sometimes. :U
Old Aug 19, 2003 | 11:20 PM
LT1driver's Avatar
LT1driver
Default Re: Check your alternator impeller fan. (Hobbes Blk '80)
thanks for the tip....will definately check mine out :cheers:
Old Aug 20, 2003 | 01:04 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Check your alternator impeller fan. (LT1driver)
Thanks for the tip, I will check mine the next time I raise the hood. :steering:
Old Aug 20, 2003 | 06:30 AM
guppie's Avatar
guppie
St. Jude Donor '08
I'm checking mine this morning, I'm changing to a chrome one.
:cheers:
To Check your alternator impeller fan.
